Old 04-15-2010, 09:00 PM   #1
gbelcik   gbelcik is offline
Lifan powered gokart
Hey guys... I had a quick question to pick your brains... i am building a suspension gokart with a 5spd lifan engine i pulled out of a motorcycle and i am currently stuck on the motor mount.
I was wondering if anyone has any ideas on how to make this motor adjustable so i can tighten up the chain to the axle. Appreciate the help
Greg
gtrail78624@gmail.com
Old 04-15-2010, 10:28 PM   #2
waynev   waynev is offline
Your best bet might be a good chain tensioner, you should be able to get within a link in the chain length and let the tensioner do the rest, if not you will have to make a mount for the motor and a plate on the chassis that it can slide on, then use an adjuster bolt to keep the motor in place.
Old 04-16-2010, 02:19 AM   #3
Welcome!
I'm not exactly sure how you're building your kart based on the photos, but I'd love to hear more.
One way to maintain constant tension throughout the suspension travel is to mount the engine on the swingarm. It's been done before.
Old 04-16-2010, 05:57 AM   #4
Welcome!
It looks like the engine will be mounted on the swingarm as those pics show, look closely W&G, that pic shows the rear swingarm of the buggy and the lifan still in the motorcycle chassis.
Old 04-16-2010, 08:15 AM   #5
katoranger's Avatar
I would go with the chain tensioner. Simplest solution.
Allen
Old 04-16-2010, 08:16 AM   #6
yeah the motor will be mounted on the swingarm
I like the tensioner idea... didnt even think about that. do you know a place to get one cheap... the only ones i can find online are 100$+
Old 04-16-2010, 08:48 AM   #7
Since it looks like your handy you should be able to make one quite easily, bend a pc of 1/2" round rod into a C, weld a tube on the chassis that it can slide into and mount a spring to hold the tension, you can either make a wheel out of UHMW or buy one, here;s an example of a simple chain tensioner http://www.hyperracing.com/product.asp?prodid=08-600
Old 04-16-2010, 09:49 AM   #8
hmm i think i found something
http://www.scooterpart.net/products.php?id=1242
worth the 16$ to not have to set the spring
appreciate the idea
greg
Old 04-16-2010, 09:56 AM   #9
katoranger's Avatar
That should work. It won't have to take up much slack since the engine moves with the axle.
Keep us posted on the project. I just got word on my kart frame. It may be available soon. I think the 110cc from Honzuma may have to power that project.
Allen
Old 04-16-2010, 10:46 AM   #10
appreciate the idea
greg
That very tensioner was used on my son's 125 pit bike. The plastic wore out quickly. Make sure to buy a few spare rollers with it.
Old 04-16-2010, 01:15 PM   #11
Rago   Rago is offline
Definitely keeping an eye out on this project! I'm doing something similar.
Old 04-16-2010, 01:26 PM   #12
Yeah its definately a project. I keep running into new issues hah. Tonight and tommorrow im going to work on mounting the engine... My big worry is getting the engine far enough forward so the chain clears the shifter. I really dont want to move the axle back further. But if i go too far forward i may get too close to the seat and i worry a bit about cooling. Im really trying to avoid a jackshaft Fun hah
Old 04-16-2010, 01:52 PM   #13
katoranger's Avatar
I think that some air scoops to help cool the engine would be a good idea.
Mounted to either side of the seat. Some HVAC ducting from home depot.
Allen
Old 04-16-2010, 02:08 PM   #14
That was actually exactly what i was planning to do. Just mold some "ram air" funnels
Old 04-17-2010, 10:25 PM   #15
well i got everything cut up and located for the mount but it looks like there is no avoiding adding a jackshaft with another couple sprockets to get to the drivetrain... has anyone ever messed with extending the driveshaft out to clear everything to go straight to the drivetrain? another thing, who sells sprockets for this engine... i would like to get a standard #40 sprocket for this thing... it would make getting to the drivetrain alot easier if i have to use a jackshaft
thanks
greg
[/img]
