A couple of questions.
Today, I rode my new Zong for 151 miles, putting the odo at almost 450 miles. Within that trip I was stranded on the highway for the easily-avoidable problem of running out of gas not only once, but two times! 8O I was lucky to have my dad riding with me to run to the gas station and get some fuel, or I woulda been SOLx2.8)
My first question is this, have any of you (not only Zong owners) ever rigged an emergency fuel can or jug to your bike? I was thinking of a way to rig something to the underside of the stock license plate/tail light bracket. It would be discreet and more importantly: available. Question two, Is there any way to help the Zong breathe? Maybe drill some holes in the air box lid or put a conical filter on? It seems extremely restricted. Although, I do have the suggested Turbine Core 2 silencer coming in, do you think this will help the situation or should I search other options? |
does your tank have a reserve? For airflow you can get a UNI pod airfilter or similar filter for about $15 online or at a cycle shop. this will increase your airflow, but you will need to richen up your jetting/needle position to make a power difference and avoid running your engine very hot.
Dune buggy build http://chinariders.net/modules.php?n...wtopic&t=14470 400cc lifan build vid: http://youtu.be/20HoU8OK_Y0 other fun: http://tinyurl.com/wildalaskan |
Yes it has a reserve, but not much of one! The first time I ran out, I was about 5 miles away from the nearest station and the reserve got me about 2-2.5 of them. The second tine I was nearly 9 miles away and again, it got me about 2-2.5 miles before running out.
I'll have to agree on the Uni filter....though I'm gun-shy on them as I dang near burned the Mrs 2LZ' Hensim to the ground with one.
The good part? It breathes real well. The drawback? It's mounted on the carb. Backfires fire right into them and if there's any gas vapor, it goes up like a ping pong ball between your legs and then you have huge flames surrounding the fuel cell if you're hanging on the side of a hill....like my firend was. 8O I went back to the stock box as it has a longer tube before the foam element. I did run my extra Uni on my new GY.....but I got a bent piece of new radiator hose and mounted it 'off the carb' to try to eliminate that direct backfire hit into the oiled/fueled foam. Concerning the fuel distance....all you can do is watch your miles, unless you want to strap on a lawn mower can or get a bigger tank. Mrs 2LZ rode a Sportster for years. We tanked up constantly. My big V Twin never ran below half tank! 8) ![]()
I bet that's why Spud put the Clarke tank on his... Might be worth looking at? Though I have no idea what they are worth, might be pricey! Another option would be to carry a small fuel bottle with you that holds a couple of liters or something, would probably get you to the next gas station
for my airbox i took it apart and took the heat gun to the little black plastic restrictor plate in front of the mesh and cut it out by heating it up then cutting it. Now my bike doesn't get starved of air
#7 | ||
Re: A couple of questions.
![]() http://tw200forum.com/forums/58824/ShowPost.aspx Since I installed a 4.1-gallon, Clarke fuel tank, I now have two, new, 2-gallon, Rotopax fuel containers for sale. If you like, I will sell you one, or both of them. ![]() http://www.rotopax.com/gasoline-pack...tv-ga-c-1.html The Rotopax fuel containers don’t leak, unlike the Kolpin fuel containers. ![]() Quote:
![]() http://tw200forum.com/forums/9572/ShowPost.aspx If you are going to ride offroad, I would not install a conical air filter. Indeed, I personally think it is unwise to alter the airbox on a constant velocity carburetor. However, after you do some research, you can make your own decision. ![]() In my experience, the Zong inhales quite well. ![]() Also, the Zong is geared too high from the factory. If you install a smaller, 13T, or 14T countershaft sprocket, the bike will definitely perform better. ![]() Spud ![]()
on my gy-5 i can only get about 10 miles on the reserve, but if i tip the bike to the petcock side then the fuel from the lobe on the otherside of the tank will flow to the correct side. i would check and see if your tank has this defect
I would not go to a conical filter. One, it will get dirty and perhaps fail. Another reason is CV carbs are an abject PIA to tune and I would leave well enough alone. Swaps pipes and jets, declare victory and move on.
Your dad has earned the right to bust your chops the rest of his life, you know that, right? :P
Happy to serve. |
#10 | |
![]() ![]() Spud ![]()
#11 |
I do like Wild Alaskan sugested. Tipping/leaning the bike as far as possible to the side with the petcock has gotten me the last several miles needed to get gas many times.
#12 | |
My stock tank reserve was worthless also. Allen
#13 | |
I'm gonna read up on this a little more and let you guys know what I end up doing. Thanks for all the input, as always! |
#14 | |
![]() Since the Zong fuel tank only has a 0.2-gallon reserve, you need to be diligent to fill the fuel tank regularly. The reserve tank will only take let you travel another 15 miles. ![]() ![]() Spud ![]()
#15 |
0.2 gallon reserve? Another WTH are the Chinese thinking?! :roll:
I'd be thinking a Clarke tank and a different petcock. :idea: On the other hand I can't say much because Q does not have a tripmeter, and as a further irritant the odometer measures kilometers. When I gas up I memorize the last digits and calculate range based on that. On the bright side, I have a 1 gallon reserve good for about 70 miles.
Happy to serve. |
