View Poll Results: What kind of work do you do? | |||
Professional (Doctor, Lawyer, etc) |
6 | 18.18% |
Mechanical |
6 | 18.18% |
Technical |
5 | 15.15% |
Computer - Software |
2 | 6.06% |
Computer - Hardware/networking |
4 | 12.12% |
Sales |
2 | 6.06% |
Self-Employed |
4 | 12.12% |
Service Industry |
1 | 3.03% |
Stay at home parent |
0 | 0% |
other |
3 | 9.09% |
Voters: 33. You may not vote on this poll |
#1 | |
Chain Adjustment
Sorry to keep bringing issues up about the chain but I am confused.
The new Dual Sport Prep page http://www.chinariders.net/modules.p...showpage&pid=6 Says: Quote:
This is a Big difference. 20 mm is about 3/4 ". 2" is 50mm. Which is right? If I try to keep mine at the 10-20mm range it always ends up in the 1.5" - 2' range within 2 rides. If I leave it at this larger amount of play it seems to stay there for 5 or 6 rides before an adjustment is needed. The larger play does seem to rub on some of the rubber pieces on the frame though. Can one, or more, of you mechanical genious' with years of experience tell me if my owners book has a mis-translation with the 10mm - 20mm freeplay on the chain. Oh thank you great and knowledgeable ones! ![]() |
Sounds like you need a better chain, that is a lot to stretch in such a short period of time.
Is that the original manufacturers chain? If so it might explain why they went with a 520 chain on some models. I usually get somebody to bounce on bike,while I put my hand on a portion of the chain that will not catch my hand, and try to collapse the suspension to see if there is too much tension on the chain with a load on, don't want to go over a bump and have the chain becoming a stressed member of the frame. Generally with a load on it you want to feel a little slack but not have the chain taught and rigid, feeling like it's being stretched. Not an expert but I play one on the internet........ :wink: |
Eddy...hey, I do that too...play an expert on-line!
Anyway...he's right...you DON'T want a tight chain. You want some slack even while sitting on the bike and riding. I have about 1 1/2-2 inches on my Ninja when noboby is sitting on it and about 1/2 inch looseness when on it. I'd bet they mean 10-20mm when someone is sitting on it. Because that is WAY too tight otherwise. The QUICKEST way to ruin a chain is to have it too tight. Hmmm...maybe THAT is why there seems to be such problems here with chains? People have them too tight? But don't keep it loose enough where it can "jump off" the teeth. |
I got a lot of chain stretch on the diamo at first, and I know how to adjust chains. The chain is of quite low quality and I plan to order an O ring DID replacement soon. That will fix MY problems with the chain.
BTW, the pole has no corrolation to the subject matter. ![]() |
It was the first poll that I had tried on here. I didn't realize that it linked it directly to the topic of the post. :oops: I thought it created a seperate item.
Thanks for the chain tips. I kept thinking that 10-20mm sounded awfully tight. All of my past bikes recomended a lot more free play. I just checked it while I was sitting on it. It is about 20mm. When I am off the bike it is about 2". I was adjusting it whithout anyone on it, so I was forcing the stretch! Thanks joerocker!!! I won't ask anymore chain questions...I promise. ![]() Hmm... does anybody make a dual-sport bike with shaft drive? :wink: |
#6 | |
2004 KAZUMA CHEETAH 200 2001 Yamaha Big Bear 400 1986 Honda ATC 250ES 1983 Honda ATC 200X 1974 Kawasaki KE100 |
I knew that that there was a shaft beemer DS but didn't know about the MG.
Heavy and expensive. :( My buddy has a BMW (not DS) and maintenance is expensive, not to mention the fact that there is NO BMW shop in the Indianapolis area. He has to go 2 hrs to Ft. Wayne or 2.5 hrs to Lousville for service. Sorry I am getting off topic. ![]() |
I know when the chain is adjusted properly that you should have about 20mm of free play with the suspension compressed. I have been using the take a cargo strap to compress the suspension method. Unfortunately everytime it ends up too tight or too loose. Am I missing something here? My rear shock is about as stiff as they come and my skinny arse only compresses it about an inch (if that) when on the bike. Does this have something to do with my outcome? The adjusters on my clone are about as lousy as they come as well. Any suggestions? Thanks...
2000 MZ Baghira |
Stiff rear suspension
My rear suspension on my GY200 was also extremely stiff when I first had it. It was a real spine killer . However after dismantling the linkage I found that it was poorly greased, and the linkage bolts that pass through the frame and swinging-arm had been over-tightened, and therefore had been pinching the linkage. After fixing these problems the rear suspension is hell of a lot better.
#10 |
Thanks for the info. I have greased the swingarm, but never thought of it being too tight. I will check this out.
I didnt have any problems adjusting the last chain, just this new one? Wierd.
2000 MZ Baghira |
#11 |
Sorry, I was a bit unclear. I meant the rear suspension linkage. The bolts I mean are the four bolts you can see in the photo below.
http://www.nalyd.freeserve.co.uk/GY200/GY200Linkage.JPG |
#12 | |
#13 | |
Re: Stiff rear suspension
2000 MZ Baghira |
#14 |
I used a chain tensioner on mine
![]() and here how I fixed the chewwed rubber slider ![]() |
#15 | |
2000 MZ Baghira |
