Zongshen 200GY-2: Teikei MV28 Carburetor Tips
Zong owners are very fortunate that the Sierra 200GY-2 is such a close copy of the currently produced, Yamaha TW200 motorcycle.
![]() ![]() ![]() http://tw200forum.com/forums/ The TK MV28 carburetors installed on our Zongshen motorcycles are slightly different from the TK MV28 carburetors installed on the Yamaha TW200. However, most of these minor differences work in our favor! ![]() The Yamaha carburetor employs two throttle cables, located on the right side of the carburetor; the Zongshen carburetor employs one throttle cable, and a return spring, located on the left side of the carburetor. The Yamaha carburetor jet needle is not notched for height adjustment; the Zongshen carburetor jet needle is notched. ![]() The Yamaha carburetor has a choke knob located on the carburetor body; the Zongshen carburetor has a remote choke adjustment, located on the left handlebar. The TW200 pilot mixture screw is hidden under a brass cap, on the bottom of the carburetor; the Zongshen pilot mixture screw is easily accessible on the left side of the carburetor. ![]() Despite these minor differences, the two TK MV28 carburetors are essentially the same. Therefore, I have provided a few links to TK MV28 carburetor threads located on the Yamaha TW200 forum. The first link, authored by Centerline, provides excellent photographs, and a detailed description of adjusting the TK MV28 carburetor jet needle, and main fuel jet. ![]() http://tw200forum.com/forums/1/28976...ost.aspx#28976 The next link provides a lot of good, general information concerning TK MV28 carburetor removal, rotation, and cleaning. ![]() http://tw200forum.com/forums/71353/ShowPost.aspx Also, if you are interested in TK MV28 carburetor jet information regarding the Zongshen Sierra 200GY-2, you might enjoy reading the following thread, posted here, at China Riders. ![]() http://chinariders.net/modules.php?n...ewtopic&t=9165 Spud ![]()
zong jets,,,,
eureka!! so following spuds advice, I took the top of the carb without removing it and put the clip back up one notch were it was ,,,but i left the 137.5 jet in cause the others haven't come in yet.It is amazing that one small adjustment has made it run good again,granted it may still be rich ,I'll have to do a plug check but it ran well, no breaking up at higher rpms and very very little pop on deceleration.
Good news! Can the clip be moved up one more notch?
zong carb
yes it is in the middle, right were itwas from stock.I could probably move it up one more nothc and leave the 137.5 jet in there,Its running pretty good the way it is .Gotta get ready for work now ,so Tomorrow will try and do a plug check.
#5 | |
Re: zong jets,,,,
![]() As a general warning to all Zong owners, be careful when you replace the slide diaphragm after adjusting the jet needle position. ![]() ![]() Carefully inspect the diaphragm to insure it is seated properly, as shown below, before you replace the top cap on the carburetor body. ![]() ![]() I wish to thank Centerline for these excellent photographs he originally posted on the TW200 forum. ![]() Spud ![]()
zong diaphram
i should probably recheck that spud ,I was in a hurry and its kinda dark where i was working.
#7 | |
![]() ![]() Spud ![]()
zong carb
i ordered a 132.5 and 135 from rocky mtn. thanks again for the link spud, ,,,Going to wait till they come in ,,then try again, see ya ,,gotta go to work!
#9 | |
Re: zong diaphram
![]() ![]() Unlike the Yamaha TW200 motorcycles, which are jetted very lean for EPA purposes, I think the stock, Zong jetting is pretty close to ideal. ![]() ![]() ![]() Spud ![]()
#10 | |
Re: zong carb
#11 |
the needle and main jet should be adjusted independently, the main jet controls 3/4 to full throttle only. unless it is excessively small or clogged.
the needle jet effects 1/4 to 3/4 throttle when the main jet becomes the main restriction. if you want to know way too much about jetting this is a great guide http://www.mikuni.com/pdf/vmmanual.pdf
Dune buggy build http://chinariders.net/modules.php?n...wtopic&t=14470 400cc lifan build vid: http://youtu.be/20HoU8OK_Y0 other fun: http://tinyurl.com/wildalaskan |
#12 | |
thanks bro ive been asking people and searching for something like this ! thanks man!
450-WheelieBoyz a.k.a. BlockHustler1000 -2011 X31 Gio 250cc- Mikuni Upgrade Air filter Hydro-clutch Reppin -> Montreal, Quebec, Canada |
#13 |
Wow! It has been many many moons! My Zong has sat for years now. I had some unpleasant experiences with tailgaters inches off my Zong twice. I quit riding obviously. Time to get her running. Pulled the carb after loosening the airbox/battery holder. Not as bad as I thought. Opened the float bowl. Melted plastic or fuel line from years of gas. The float was frozen. Usually the pin just falls out, but not the case. Must be pressed in. At any rate I am taking a chance on this carb. It looks like the exact original. I looked at the the TW200 carbs with manual choke, but I like the handle bar choke control. I'll let y'all know how it works!
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1 |
#14 | |
I don't like the cable choke due to cables getting stuck so I have a manual choke |
#15 |
My Zong was running great almost 6 years ago. Unfortunately the fuel seems to have corroded everything and melted the pickup tube as well as the rubber/silicon fittings. Easier for me just to replace it.
