View Poll Results: next mod?
re-jet(will smooth out the engine response and allow for different exhaust) 4 30.77%
acerbis brush guards(protection) 6 46.15%
stainless brake lines (better braking feel) 1 7.69%
42 rear sprocket (better cruising rpms, less off road torque) 2 15.38%
Voters: 13. You may not vote on this poll
Old 03-20-2007, 01:57 PM   #1
mdsuave13   mdsuave13 is offline
Send a message via AIM to mdsuave13 Send a message via Yahoo to mdsuave13
a few questions..
#1. Has anyone come up with a good solution to the chain slider? Mine with only 128kms on the dial is about halfway thru it.. I dont know if it will wear further, but i know my rim is COVERED in black rubber.. So i was curious to see what everyone is doing, or if it just wears to a point then stops..
What happens if it wears straight thru and i dont change/fix it?
#2. I need 3 people who would like to get the next size up jets for our fml163 family of engines. Let me know via pm if you would be down to go in on this, and i will get a price of what it will cost to get it.
#3. Has anyone replaced their factory hand guards "windbreakers" with acerbis or other misc hand guards? I want to get rid of the cheapo ones cause they are pretty terrible.
ps.. i also am looking for nintendo games (nes, snes) lemme know if you have any you want to sell to me. haha.. im an old school gamer...
My name is Justin, my friends call me Stix.
2008 Kawasaki KLR650 Candy Lime Green
______________________________
I am the official China bike registration Guru For the State of Maryland..... HA.
Old 03-20-2007, 03:02 PM   #2
Re: a few questions..
Remember it's not necessarily the engine but the carb. I'm not sure that all the china bikes have the PZ27 carb that Red2003 was refering to. Some even have the PZ30, while others have ???
Jason
2008 Jonway MC-70-150
2007 Roketa DB-07B (RSM-200E)
2006 Roketa DB-07A (RSX-200E)
Old 03-20-2007, 03:13 PM   #3
indeed... i'm not sure which carb i have.. i do believe i will have to go check.
Old 03-20-2007, 03:31 PM   #4
Also, isn't your's a push rod. I thought only the OHC versions were 163fml. Mine's stamped on the engine right there at the gear shifter 163fml
Jason
Old 03-20-2007, 06:01 PM   #5
pumpkin   pumpkin is offline
i took my hand guards off. i couldn't figure out how to keep the clutch lever from sticking without the turn signal being loose. with guards off it worked out fine. i didn't like them anyway.
06 american lifan 200 gy-5
Old 03-20-2007, 06:50 PM   #6
PolygonFla   PolygonFla is offline
#1. Has anyone come up with a good solution to the chain slider? Mine with only 128kms on the dial is about halfway thru it.. I dont know if it will wear further, but i know my rim is COVERED in black rubber.. So i was curious to see what everyone is doing, or if it just wears to a point then stopsmdsuave13
mdsuave13
I read a post some place about a guy going to walmart and buying a nylon cuting board and cuting a strip out of it with a band saw and riveting it in place. I don't remember if it was thumpertalk or a private blog.
I'm only doing the brake line cause I broke mine, otherwise I was considerin the rear sproket.
Old 03-20-2007, 08:10 PM   #7
gyjoe   gyjoe is offline
There have been a few members who have improvised a replacement--do a search on chain slider.
2006 Lifan LF200GY-5
Old 03-20-2007, 10:19 PM   #8
yea, i've seen most of the improvised fixes. but i dont recall seeing follow ups to those fixes I.E. did it work out in the long run, was it worth the effort etc.
I remember the cutting board one as wearing down also.
what i am curious about is how far it will actually wear thru. It seems on mine that the side links wear into the rubber deeper then the rollers do. I'm wondering if it will wear to a point then the rollers will just roll over the rubber and the links will sit in their grooves.
I guess i will just see how it pans out and then looks for a viable solution.
Should i be worried about it wearing all the way thru the rubber onto the swing arm? will this cause the chain to self destruct?
Old 03-20-2007, 11:46 PM   #9
ambassador   ambassador is offline
Suave,
I think the original will hold up for the most part, if not try th EZ fix and cut up a cutting board from wally world and don't keep your chain too loose, I'm surprised your having a prob w/ that???
06 Lifan 200 GY-5
Old 03-20-2007, 11:50 PM   #10
yea, well i leave about 1/2" slack (total movement up and down) in the chain when im sitting on it... but its not worn thru yet, but im just curious how far it will wear thru before its chillin...
Old 03-21-2007, 12:01 AM   #11
One of the guys on here posted a scooter link that has a direct replacement for it, I'd have to go look again, I know you've seen it...
06 Lifan 200 GY-5
Old 03-21-2007, 12:17 AM   #12
chris5150   chris5150 is offline
Send a message via AIM to chris5150 Send a message via Yahoo to chris5150
the cutting board thing was done by imeazy, pm him and see if he has any info for you. and post back letting us know what he told you.
Old 03-21-2007, 12:19 AM   #13
That's what I meant by the EZ fix, search the post...
06 Lifan 200 GY-5
Old 03-21-2007, 03:46 PM   #14
ImEazy   ImEazy is offline
http://www.chinariders.net/modules.p...ighlight=#3837
Meant to say that they have cutting boards at Target for $1.98. Cheaper than Walmart at $4.
2000 MZ Baghira
Old 03-21-2007, 04:39 PM   #15
yeah, i saw that.. i dunno, i guess that will be my alternate plan if plan A fails...
for those of you that dont know plan A, its leave the stock part on and see what happens in the upcoming miles
