Mono Shock Replacement
I rode my Chinese copy just a little too hard. I have a gy-200 2005. The bike as served me well and I have had no problems until now. I hit a hill just a little to hard and over extended the Mono shock in the rear and it is now broken at it weakest point at the top near the top eye. I welded it and I was sure it was going to hold but no luck. It will not hold and needs replacing. I have found no information on a suitable replacement. The shock is around 11 1/2 inches eye to eye which is a rough guess since mine is damaged. The shock can be or was adjustable. The top eye and bottom eye are the same size and I am sure they are metric but close to 1/2 an inch in diameter. Has anyone found a replacement?
keep us posted if you decide to start testing the ones from the xr200.
I just happen to have an XR200 shock out in the shop.
I will post accurate dimensions over the weekend. |
#5 | |
Jason
Is this the right one?
http://www.jetmotousa.com/part_info.php?pid=2548470 Or maybe this one? http://www.jetmotousa.com/part_info.php?pid=2548229 |
The second one looks like my Roketa, only mine has adjustable preload.
The roketa I just got (the 2005 I have been complaining about) is like the first one. It has the threads on the shock body.
I'd have to agree the first looks more like what I have and mines a 2006.
Jason
#10 |
Jason, your 06 has the 1st type with one open and one closed end on the shock?? Mine doesn't. That's kinda weird??? Here is my rear assembly. Notice the shock on the left.
http://www.terminatorscooter.com/product/parts_detail.jsp?partId=11587&partName=REAR%20WHEE L%20ASSEMBLY(4)
#11 |
Still no luck no replacement has been found yet. I have found orginal replacement but i was hoping to find a betterr one without having to modify the shock mounts.
#12 |
Shane, If you found the original then I would go with that, I don't think you're going to find any good aftermarket shocks without having to modify them...Look for an earlier post here about this...
06 Lifan 200 GY-5 |
#13 | |
Jason
#14 | ||
#15 | |
You're right about it being stiff. After 5000miles I'm glad to have a slightly bigger more road worthy tire on the rear. I can ride fairly comfortably with about 20-22psi. Otherwise it's almost like riding a hardtail. Jason
