Old 09-25-2009, 10:46 PM   #1
undertulsa   undertulsa is offline
Dying and coughing, and spitting
Ok, bike will start and run for a while then it dies constantly, backfiring, running rough coughing. dumped fuel cleaned filter, still doing it, have new ngk spark plug, tried 3 different cdis i have in stock to no avail.
totally stumped!
bike has 1300 mi owned since new, tired new gas no solution. :roll:
Old 09-26-2009, 01:09 AM   #2
forchetto   forchetto is offline
Those symptoms are exactly what you get if there's water or other matter blocking one of the carbs jets. Probably the idle jet as this is very small.
It happens a lot to people that have ditched the air cleaner and replaced it with pod-type filters. If they get wet through rain or washing, the water droplets get sucked into the carb and a tiny bit of water can block a jet.
The ideal thing is to dismantle the float chamber and jets and blow through them to clear the blockage.
An old dodge is to remove air filter, get the revs as high as you can considering the fault, and immediately block the carb intake with your hand. The suction that results usually clears the blockage.
Jincheng Monkey JC50Q-7 (two of them)
Skyteam Dax replica ST110-6 (two of them)
Zongshen ZS125-43
Qingqi QM200GY-BA Super Motard
Yamaha Virago XV1100
Triumph Bonneville SE
Qingqi QM110GY
PGO Bug rider 250 Buggy
Old 09-26-2009, 10:13 AM   #3
Carbs and Valves
Anyone know of some good threads about checking carbs, valves? gy200 2007 A.
Thanks!
Old 09-26-2009, 10:14 AM   #4
Gas
Do I have to drain tank to work on carb?
Old 09-26-2009, 12:34 PM   #5
katoranger's Avatar
Re: Gas
Just need to turn the fuel off on the petcock.
Allen
Old 09-26-2009, 12:49 PM   #6
Reveeen   Reveeen is offline
Adjust the valves.
Old 09-26-2009, 02:08 PM   #7
black smoke
Ok something definately wrong black smoke, bike will idle but dies if i give it any gas like it cant get gas?
can anyone give me some valve adjustment instructions. do i need any special tools, and basically i know how to remove cover but thats about it, anyone know of threads that show me how to do this right?
videos would even be better, any reason i shouldnt just take this to the bike shop as i could really mess it up.
need your advice guys.
Old 09-26-2009, 02:39 PM   #8
katoranger's Avatar
Black smoke usually means too rich.
Old 09-26-2009, 02:40 PM   #9
katoranger's Avatar
Valve adjustment tutorial.
http://chinariders.net/modules.php?n...ewtopic&t=1655
Old 09-26-2009, 03:34 PM   #10
thankS
well Ill get after it, do i need something to like a spacer to measure, micrometer or something to adjust them. anyone know what the specs for 2007 gy 200 A are?
Old 09-26-2009, 03:43 PM   #11
feeler gauge
do i need one? feeler gauge, what mm do i need for the lifan 2007 gy200 a?
Old 09-26-2009, 03:46 PM   #12
too rich
ok if i have it too rich theres a possibility that i dont need to adjust valves at all right? how do i get a leaner mixture? is this a carb adjustment?
how about a carb thread?
Thanks guys realize this is pain but really need the help. Might start with that as i think carb is problem.
Old 09-26-2009, 04:19 PM   #13
two china bike valve adjustment videos.
looks pretty easy just need that tool. think my bike is .04 mm can anyone confirm?
Still think my carb needs adjusted think its running rich as Kato suggested, think my prob is carb less valve adjustment
Old 09-26-2009, 05:32 PM   #14
I very much do not think it's related to the valves. Something is gummed up in the carb, I'd start there.
Old 09-26-2009, 06:02 PM   #15
Concur
I agree, starting to dismantle the carb, god help me!! wish me luck because this is a long way from anything ive done so far.
