Old 09-18-2009, 08:06 PM   #1
undertulsa   undertulsa is offline
Electric Problem 2.0
Ok, gy-200, 2007.
Heres the symptoms:
bike initially starts runs great and has no problems till ive been riding about 30-45 with the brights on **(because about 3 people a month get killed out here in Albuquerque NM being flattened cars).
So if i turn it off it acts like the battery is dead or severely drained and i have to bump start it or kick start it. It will run fine all lights will work fine but the starter will not work again till it cools off.
had battery tested - passed. Since there isn't an alternator what the heck do i check?
:roll: [/u][/b]
Old 09-18-2009, 09:07 PM   #2
Sounds like a starter problem. Is there a possibility that the exhaust pipe is too close? If so, perhaps you could fabricate a heat shield or wrap the pipe (or both).
If those things don't help, seek out a new starter.
Old 09-19-2009, 09:35 AM   #3
more info
Ok, battery had to be charged to get bike to restart after overnight, battery definitely not getting alternator power up. wheres the alternator? Is it replaceable? or is this a coil issue gone bad?
Old 09-19-2009, 02:12 PM   #4
battery
Ok battery is definitely not getting a charge
Old 09-19-2009, 04:53 PM   #5
china_parts_canada   china_parts_canada is offline
Send a message via MSN to china_parts_canada
Hi,
What happens after the 30 to 45 minutes? Does it quit running or if you shut it off it will not restart?
If it just quits running I would think it is either the CDI, coil, or spark plug.
If the battery is going dead then it is likely the battery, stator/alternator, or the regulator/rectifier.
Cheers,
Art
Old 09-20-2009, 10:31 AM   #6
Cant Believe
Ok you wont believe it. After getting out the multimeter and a alternator tester I traced it down to that little fuse attached to the battery positive cable. The fuse had almost slipped out of the holder but was still barely contacting. However, once i put it back in the fuse holder correctly the battery and starter worked after a brisk ride to charge back up.
Tested all afternoon, starter never failed again. Once again proving that the simplest answer was the solution.
Thx for everyones input it helped me arrive at the solution.
Old 09-20-2009, 10:37 AM   #7
katoranger's Avatar
Thanks for following up with the solution.
