Old 08-28-2009, 10:27 AM   #1
undertulsa   undertulsa is offline
Spitting
200-GY, 2007 - when I get the bike up to 50-55 it sputters and kinda coughs like something is missing?
Thoughts experts
Old 08-28-2009, 11:29 AM   #2
I'm no expert.
Since you can likely move through the gears without any other trouble, I'd start by looking at the electrical side. Have you installed a genuine NGK lately? If so, maybe the plug wire is bad (you can also change that for an NGK and lose about 1000 ohms of resistance).
Old 08-28-2009, 11:39 AM   #3
?Slide
Replaced the spark plug per our earlier discussion. havent done the wire will consider next. What is the electrical slide?
Old 08-28-2009, 11:40 AM   #4
My HSUN will not rev past 7500 without the same symptoms. Ditto my buddy's identical bike. I thought it was the CDI's rev limiter kicking in. Our bikes do the same thing at about 55.
Both have aftermarket rev limiters. The origianls went Tango Uniform.
Old 08-28-2009, 11:56 AM   #5
FastDoc, When they went Tango Uniform, did you say Whiskey Tango Foxtrot?
Did the aftermarket rev limiters solve the problem, or does the bike still sputter?
undertulsa, I'm saying electrical side, not slide, meaning not the fuel or air side of the equation. Make sense?
Old 08-28-2009, 12:01 PM   #6
got ya
electrical side ok duh moment.
Can you get a spark wire at any bike shop or is this a paypal situation?
Old 08-28-2009, 12:03 PM   #7
tango
Ok someone want to explain tango uniform.?
would that be like foobar?
Old 08-28-2009, 12:10 PM   #8
Do you know the phonetic alphabet? Alpha, Bravo, Charlie...
Old 08-28-2009, 12:27 PM   #9
Cal25   Cal25 is offline
Re: Spitting
Thoughts experts
Is that when at full throttle? Does it smooth out if you ease the throttle a bit from full throttle? Any changes to the bike like exhaust, carb, jets?
Old 08-28-2009, 12:31 PM   #10
DesertRider   DesertRider is offline
Re: tango
urban dictionary : tango uniform adj – slang: military phonetic alphabet for letters ‘t’ and ‘u’, used as euphemistic abbreviation for ‘tits up’.
Or he could have meant a "Tango" "Uniform" ?????
EX: Zong owner
Old 08-28-2009, 12:48 PM   #11
yes it does
oH TITS UP, HA
no changes to throttle or adjust carb jet.
850mi, yes it smooths out when i back off.
Old 08-28-2009, 12:54 PM   #12
Yup. 8)
I was lucky to get home when they took their respective dumps.
The 'cutoff' was the same with the original and aftermarket CDI's.
Old 08-28-2009, 12:58 PM   #13
Based on my experience, I'd bet it's (Chinese standard) normal. Maybe one of us has tried one of the 'race' CDI's which supposedly remove the rev limiter, if there is such a thing.
I think, for me at least, 55 MPH and 7,500 RPM are reasonable operating limitations for a little 200 cc OHV engine. As long as it continues to run well I'll quit while I'm ahead.
Old 08-28-2009, 02:05 PM   #14
Has anybody tried an NGK plug wire?
Old 08-28-2009, 02:29 PM   #15
liverchip   liverchip is offline
Send a message via MSN to liverchip
I replaced the plug cap with an NGK due to cracking on my old one, but not the whole wire. No notable change in performance.
2009 XR650L Big Red Pig
Tusk bar risers
2007 X-Moto(Jetmoto) GY250
--mods---
15/40 sprockets
UNI Pod Filter
2007 Shineray TMS 200XYi--Betsy
Betsy Mods:______________________
Acerbis DHH headlight
FMF Powercore pipe
Uni Pod Filter
