Old 08-18-2009, 11:34 PM   #1
heretic   heretic is offline
125cc Gio dirt bike clutch problems
My daughter heated up her 125 today so hot it melted the end of the oil dipstick off 8O Now the clutch will not work changed the oil .tried adjusting it still the clutch will not disengage .Any ideas?I took the case of but all seems fine there .Anybody know how to get the clutch off is there a special tool for undoing the nut underneatth the plate .Please help shes devesttaed thinking she might not ride again this year .The bike only has about 20 hrs on it :(
Old 08-19-2009, 08:09 AM   #2
Reveeen   Reveeen is offline
These things seem to run hot, but not quite that hot, what are you running for oil? Have you adjusted the valves? (a "tight" valve will cause it to run hot).
Valve adjustment info:
http://www.hooperimports.com/showpages.asp?pid=1016
Break-in procedure:
http://www.hooperimports.com/showpages.asp?pid=1026
Ok, now clutch adjustment:
The cable has 2 adjustment spots and under the small right side cover there is a coarse adjustment.
Taking the clutch apart:
General info:
http://www.dansmc.com/clutches.htm
Specifically (the tool required)
http://www.chinariders.net/modules.p...ewtopic&t=8178
Old 08-19-2009, 11:25 AM   #3
This is cheap insurance to prevent another overheated clutch: http://www.scooterparts4less.com/web..._OilCooler.htm
And here are the tools: http://www.scooterparts4less.com/web...lutch_Tool.htm
Old 08-19-2009, 11:15 PM   #4
Thanks guys thats all the info i needed . 8) I'm thinking maybe the plates are stuck together from the plastic .Im going to take it apart and try repairing it before ordering another clutch .You guys are awesome thanks again that oil cooler looks like a must have .Thanks again
Old 08-20-2009, 12:32 AM   #5
AZ200cc   AZ200cc is offline
Good luck, Hope that's all that melted 8O Did it sit idle while running for a long time? Or did the motor get caked with mud?
Old 08-20-2009, 01:50 AM   #6
If you move forward with the oil cooler, might I recommend a muffin fan? Muffin fans (the same type found in PC cases) run on 12 volts, and it could be easily zip-tied to the oil cooler. I'm sure that you could find a 12 volt power source coming off of the stator.
If not, there's always LynnEdwards!
