Replacement Rims , Northstar 250
Bent my right rear rim on my second run.
Do chinese atv/quads use a standard bolt pattern ? Will a rim from other quads fit these bikes? This quad has very small bolts from the rear hub unit that bolts to the axle shaft, it looks like a 4.5 in diameter. Thank You |
