Old 07-16-2009, 12:51 AM   #1
lonfu   lonfu is offline
bestpriceatv.com
From bestpriceatv.com I ordered one of the Buyang(Woodsmen) 300's 4x4, got it in record time in perfect conditon. It developed a drip leak from the weep hole in the water pump. I called the dealer and talked to the overworked parts department. They sent me a replacement, wrong one, called again. Emailed them a picture and they sent the right one. No charge, problem solved. Runs great and is a great machine for the money.
This is my third chinese atv, I have found that the electrical plugs and switches are very weak and often fail in some way. Have your ohm meter handy!!!! I have found that often the wires pull out from the crimp connector in the plastic plugs on the wiring harness. Hard to see too!!! Good mechanically just weak switchs and plugs. Wiring harness probly made by house wives in their kitchens, small hands can't crimp the connectors tight enough, wires slip out. I figure I saved at least $3k.
2007 4x4 300 buyang atv <br />2009 4x4 300 Buyang atv<br />1985 yamaha v-max/2009 fuel inj Yamaha Rhino
