Old 07-04-2009, 06:39 PM   #1
undertulsa   undertulsa is offline
Oil
question on oil type.
I need suggestions on type of oil, i plan on staying with dino oil for 1000k
But will any 10-40 motor oil do or do i need to get special motorcycle 10-40 oil?
Thx and happy 4th.
Old 07-04-2009, 07:45 PM   #2
dsrt4   dsrt4 is offline
Rotella 15w-40
Or Motorcycle designated Motor oil.
I have Rotella in every bike I have.
Old 07-05-2009, 01:41 AM   #3
Jim   Jim is offline
I just use cheap Penzoil 10 - 40 motorcycle oil, but I am not an expert on oils.
"Be excellent to each other"
Old 07-05-2009, 01:35 PM   #4
lobo   lobo is offline
Send a message via MSN to lobo Send a message via Yahoo to lobo
I had the same question at one time i own a 2006 Roketa DB-07 enduro and I just changed my oil and spark plug this weekend and got everything at Autozone got one quart of 4 stroke 10w-40 it was in a black bottle think it was pennzoil but it and the plug did great
Old 07-06-2009, 05:33 PM   #5
Originally Posted by dsrt4
Rotella 15w-40
I agree. You can't go wrong with Shell Rotella T 15W-40, or, better yet, Shell Rotella T 5W-40 Synthetic motor oil.
Old 07-06-2009, 05:52 PM   #6
Rotella 15w-40
On a Side note........ Make sure to break the engine in on Regular motorcycle oil or Rotella non synthetic. I know Spud knows this, I just wanted that out in the open.
Old 07-06-2009, 08:26 PM   #7
thanks!
Yeah, Spud has prob heard me say that i would stick with dino oil until 1000k but all advice appreciated!
:wink:
Old 07-06-2009, 08:48 PM   #8
katoranger's Avatar
I used the 15w40 rotella with great success. It is cheap too.
Allen
Old 07-06-2009, 11:37 PM   #9
Oil is for wussies. I refuse to use the stuff, it makes a mess and is hard on the environment!
Rotella rocks. Synthetic is fine even in a new engine, but I think it's a waste as often as you change the oil in a bike. (BTW, I ran synthetic in my Jeep from a brand new rebuild, day one. The rings seated just fine and I had NO problems at all. That was an engine running about 11:1 compression too.)
Penzoil I wouldn't run in a turd grinder. If you change the oil every other day it might be OK, but it builds sludge FAST.. (Penzoil uses a paraffin base.) I've seen several engines destroyed from having the oil pickups clogged after running the stuff.
Just stay away from oils that say something about improved mileage, usually they have extra moly in the mix and that can make the clutch slip.
Old 07-07-2009, 11:04 AM   #10
Rotella
I get conflicting information on Rotella, is it a real true synthetic? Amsoil supposedly is? Is it better to have a true synthetic? Sounds like Rotella is the way to go, and if it works well then I dont care but I would like to get this right the first time because I do not want to change brands once I start for consistency.
8O
Old 07-07-2009, 01:06 PM   #11
AZ200cc   AZ200cc is offline
Oil is the same as beer for guys, Everyone has a favorite and the rest is swill And yes Penzoil was a sluge monster but finally changed the formula some years ago but I still don't trust it and will never run it. I like good ol Valvoline but I am curious aboutthe rotella I might try it next oil change.
Old 07-07-2009, 01:15 PM   #12
Rotella comes in two flavors; synthetic and dino. One's in a blue jug the other's in a white jug.
As far as break in is concerned... there's still some debate going on. I think it stems from the early synthetics being so darned slick and not good for either brand new engines or old, worn engines. The stuff out now has been reformulated. I broke my Jeep in with synthetic, but it was really a waste. The oil needs to be changed so frequently it's hard to justify the cost. Honestly, I don't run synthetic in any of my bikes as it gets changed so often it really makes no difference. You can open any engine that I own and I guarantee they will look good inside. I have a Toyota with 225,000 miles on the clock, when I replaced the head gasket it still had the crosshatching in the cylinders. That truck has never seen a drop of synthetic oil, just regular changes with Castrol GTX.
People will debate oil until the cows come home... I say just keep it fresh and it's all good!
Old 07-08-2009, 12:35 AM   #13
Re: Rotella
8O
Here is an interesting link that addresses your question regarding the various types of synthetic oils.
http://www.calsci.com/motorcycleinfo/Oils1.html
Originally Posted by knothead
...People will debate oil until the cows come home... I say just keep it fresh and it's all good!
Amen.
Here is another interesting link regarding motor oil for motorcycles; perhaps you might enjoy reading it.
http://www.calsci.com/motorcycleinfo...ables.html#Oil
Old 07-09-2009, 01:15 PM   #14
Reveeen   Reveeen is offline
Interestingly enough Penzoil in Canada is made by Shell, yes folks, it comes out of the very same place as Rotella.
Old 07-09-2009, 01:34 PM   #15
Cal25   Cal25 is offline
Yep, oil comes out of wells drilled into the ground
