Old 06-12-2009, 08:32 PM   #1
Jpratt   Jpratt is offline
125cc giovanni dirt bike, shifting, clutch???
My 125cc giovanni dirt bike sometimes lets me shift without using the clutch while i am riding it, is there a way to fix this?
Old 06-12-2009, 08:53 PM   #2
suprf1y   suprf1y is offline
Thats normal.
Old 06-12-2009, 09:02 PM   #3
well isnt it wearing away the clutch then??
if it does it then what is the point of having the clutch??
Old 06-12-2009, 11:02 PM   #4
It has nothing to do with the clutch, and no, it won't wear it out.
Bike trans can be shifted without the clutch.
Old 06-12-2009, 11:07 PM   #5
ok then, i was just wondering because it seems quite difficult sometimes to get the bike in neutral...
Old 06-13-2009, 12:26 AM   #6
They're all like that. Switch to synthetic motorcycle oil to minimize the problem.
The point of the clutch is starting and stopping. Once you're underway, the clutch isn't necessary.
Old 06-13-2009, 10:16 AM   #7
what type of oil should i use then???
i cant find it in the manual.
Old 06-13-2009, 10:43 AM   #8
forchetto   forchetto is offline
Oil 10w-40 semi or fully synthetic, but no "fuel saving", "energy conserving" or "low friction" type oil as they're not suitable for wet clutches.
Lots of folk change gear without the clutch. Only works properly on upward changes though. The technique is to apply pressure to the gear lever as in preparing to swap cogs and then relieve the torque holding the gearbox cogs in hard mesh momentarily. The next gear will slip in.
To achieve the load or torque relief you only have to shut the throttle an instant or if you have an easily operated kill button (not rocker switch), press that for an instant.
Jincheng Monkey JC50Q-7 (two of them)
Skyteam Dax replica ST110-6 (two of them)
Zongshen ZS125-43
Qingqi QM200GY-BA Super Motard
Yamaha Virago XV1100
Triumph Bonneville SE
Qingqi QM110GY
PGO Bug rider 250 Buggy
Old 06-13-2009, 10:58 AM   #9
so the oil that comes in the bike is junk??
Old 06-13-2009, 11:50 AM   #10
Definitely.
Get some mobil 1, amsoil, or even castrol 10w40 motorcycle oil.
The castrol is available at walmart for $4, the others are synthetic, and about $10/L
Old 06-13-2009, 08:36 PM   #11
AZ200cc   AZ200cc is offline
I just use good ol valvoline for motorcycles with wet clutch protection, I know the other oils are good but this has never let me down yet.
Old 06-13-2009, 09:51 PM   #12
well i got synthetic oil, put about 1/2 a liter in and adjusted the clutch a bit and now it shifts nicely.
Old 06-14-2009, 03:42 AM   #13
TurboT   TurboT is offline
One (me) wonders how you would notice you can shift gears without the clutch? Not something I would try myself on my YZ. Especially when I have it spooled up I'd much rather hit the clutch than click the shifter "just to see what happens" !!
I do know that a lot of manual trans cars/trucks can shift without the clutch though. Had an old 1980 Dodge I used to shift without the clutch regularly. Rule of thumb for me there was about 1000 rpm lower than when you pulled out of gear it would go into gear, but more of a feel thing. That I didn't care about breaking as much as my bike though!
Slant 6 leaning tower of power.
My Blogs:
Chinese Motorcycle Blog
A Man's Blog
Old 06-14-2009, 04:46 AM   #14
Jim   Jim is offline
You can shift anything without a clutch, atv, bike, truck, car... It's not always a good idea though...
"Be excellent to each other"
Old 06-14-2009, 04:19 PM   #15
I tend to agree!
