Old 06-08-2009, 05:58 AM   #1
smithyUK   smithyUK is offline
110 zong HELP
zongshen 110 cc pit bike
will only run with the choke on
im thinking piston rings
eny ideas folks :?: :?:
Old 06-08-2009, 12:23 PM   #2
katoranger's Avatar
Sounds like it is starving for fuel. Have you cleaned the carb and check for fuel flow from the tank?
Allen
Old 06-08-2009, 01:56 PM   #3
forchetto   forchetto is offline
Blocked idle jet?. Drain carb float chamber into a clean container and see if there's a lot of sediment, water droplets, etc. If so the idle jet could be blocked by some of it.
If it's been exposed to water, rain, washing with a hose etc, and you have one of those pod filters, the chances are that a drop of water has got through the filter and blocked the idle jet.
Jincheng Monkey JC50Q-7 (two of them)
Skyteam Dax replica ST110-6 (two of them)
Zongshen ZS125-43
Qingqi QM200GY-BA Super Motard
Yamaha Virago XV1100
Triumph Bonneville SE
Qingqi QM110GY
PGO Bug rider 250 Buggy
Old 06-09-2009, 07:11 AM   #4
cool 8)
sounds like it is starving for fuel
and it does have a pod filter will drain carb and check
thanks again guys
Old 06-09-2009, 02:00 PM   #5
Agree. Plugged soemthing in the carb. Did the bike sit awhile?
Old 07-04-2009, 11:12 AM   #6
drained carb
oh my god theres alot of sediment :o
replace fuel aswell ?
Old 07-04-2009, 11:15 AM   #7
Reveeen   Reveeen is offline
How about a fuel filter? (last ones I bought were $2)
Old 07-04-2009, 03:58 PM   #8
Originally Posted by smithyUK
drained carb
Take a look inside the tank with a torch, (or a lighted match if you're a fully paid-up member of EXIT) and see if there's dirt at the bottom, or internal rusting. If so drain tank, put in some fresh gas to rinse and remove the gas tap so that all the dirt can be flushed out.
Clean out the mesh filter in the tap itself.
Zongshen ZS125-43
Qingqi QM110GY
Old 07-04-2009, 04:21 PM   #9
thanks again forchetto
ure more help than the dealers 8)
will look tomorow (sunday)
'man who be riding bike made in china be walking home' <br />bts 125xtx :mods: dirt tyres,zong hand guards more to come
