06-07-2009, 03:00 PM | #1 |
What part is
I need a new gear and im sure of what it is called but Its the one on the left of the clutch. any help on where to get this gear would be great??Or what it is called?Is it the clutch gear?
06-08-2009, 02:04 PM | #2 |
Driven primary gear. About $90 for a genuine Honda one. Should be half that for a Chinese one.
It might assist other posters who wish to help out, by knowing where in the world you are, what is the make, model, capacity, etc of the bike. Even better the engine model number, stamped on the crankcase. I'm only guessing it's a Honda horizontal engine clone by the shape of the clutch... :roll:
Jincheng Monkey JC50Q-7 (two of them) Skyteam Dax replica ST110-6 (two of them) Zongshen ZS125-43 Qingqi QM200GY-BA Super Motard Yamaha Virago XV1100 Triumph Bonneville SE Qingqi QM110GY PGO Bug rider 250 Buggy |
06-09-2009, 02:00 AM | #3 | |
06-10-2009, 02:25 PM | #4 |
I think you mean 154FMI rather than 154FHI. The engine is made by Zongshen and it's one of those with the semi-automatic clutch. Forget the make of the bike, they're just assemblers of other people's bits. Look for a source of Zongshen spares. Specifically in dealers and websites that sell and service monkeybikes or pitbikes.
Is this anything like it?:
06-21-2009, 04:16 PM | #5 | |
08-01-2009, 01:59 AM | #6 |
Ok
So i got the part but i can not find the part to remove the clutch to replace the part any places to get that key or tool or and easy way to get the clutch off thanks??
08-01-2009, 03:53 AM | #7 |
You'll need a special spanner for that. There are lots around, the commonest is one of these. Some people use an old socket and grind it to suit. Any shop that sells spares for Honda Cubs or Monkey/pit bikes will have one of those.
08-01-2009, 03:25 PM | #8 |
Hey forchetto,
If it's no trouble, do you mind to provide specs on that socket? We could benefit from ID, OD, tab length, width, height and spacing. I'd like to make one, and I'm sure that others would as well.
08-02-2009, 02:39 PM | #9 |
Rough drawing. Forgot to put the tab length on it, it's 5 mm:
08-03-2009, 01:30 AM | #10 |
Thanks vary much that's much appreciated !
08-14-2009, 03:33 PM | #11 |
witch primary gear is it
HONDA S65 CL70 Z50 CT70 C70 XR70 PRIMARY DRIVE GEAR
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT HONDA ATC90 ATC 70 90 PRIMARY DRIVE GEAR http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT DO you know i have no idea and i cant count the teeth on the old gear because its broken? |
08-21-2009, 04:21 PM | #12 | |
Re: witch primary gear is it
