HSUN, SUNL, MDL etc. 200GY guys, question on rear suspension
All you guys that have that same *type* of bike as Waldo, I was looking at the rear suspension setup and wondering what that third hole is for...
Are these bikes adjustable for height? Seer
even
Even though im new i inspected my mono shock no adjustment, you have to get a third party replacement guessing 150.00 if you have them do it about 75.00 if you just get a great shock.
Hmmm, well mine has a multi position adjustment nut built into the shock. So there's another slight difference between the hamna and sunl i guess.
Seer
I had a chance to take my rear suspension apart the other night to grease some pivot points. While apart i adjusted the preload on the spring all the way out hoping to get my seat height just a touch lower. I did not accomplish much with the height adjustment, maybe an inch ( forget to measure before i started) BUT the ride quality has improved greatly! I would suggest this adjustment to anyone who has this bike. Adjustment may be accomplished with just a spanner wrench but the whole shock can be removed without any other disassembling of the bike.
2008 HSUN MDL-200GY 2009 KLR650 |
#5 | |
Re: even
Bug, yeah, adjusting that shock made nearly zip height diff to me too, however, as you note, made a BIG diff in ride quality. ![]() ![]() seer
I was wrong
To all, foot in mouth mine has a lower adjustment, looks like only an inch or 5 threads can be gained. I am excited this can be loosened, bet it really helps ride. apologies jumped to quick :oops:
I think my Hi Bird has the same thing. I looked carefully and could not determine a way to lower the overall height.
If you guys come up with a shock that will work to lower the seat, let us know! |
