Is there spark? I know you said new plug, but is it actually getting spark or did the cdi fail or something? Is it getting fuel? I have heard of problematic fuel pump on these. Check of the link in the sticky at the top of the scooter forum to oregonvintage. It has some great tech help.
Allen
Check the BIG three first.
Air Fuel Fire Without any of these three things, the engine will never run. Check to make sure its getting each of the above. No clogged air filters, Make sure its sparking the plug, and make sure its getting fuel. Some things to check. Air Filter - Is it clean so the engine can get air? Fuel Filter - Is it clogged and not letting fuel through? Spark Plug - Is it sparking when you hit the starter? If its been sitting for a while, the most common thing is old nasty gas. Old gas doesnt burn well, clogs up fuel filters, and gums up the carbs. |
Fuel is new, I am getting spark, Air/Fuel Filters are clean. Also, the thing runs great, I kicked it after letting it set for a day. Thoughts?
I'd bet on the CDI
Happy to serve. |
If its getting spark I would doubt the CDI. Fuel in the tank does not equal fuel in the cylynder though. Especially with the problems others have had in the past like Katoranger says.
oops i forgot to look at the post date
did you get it runnin yet. take carb off and clean it out with air make sure no debree in carb at all or at least try... fuel is being starved some how some where, take main jet out as well and clean any debree and it wont start .....just my opinion DD
DesertDog |
