Old 05-02-2009, 11:23 PM   #1
yozalo   yozalo is offline
Speedometer
I was interested in the bike speedometer but wanted to ask will it work on my atv. They sell them on ebay for about $4. Has anyone done this mod.
Old 05-02-2009, 11:59 PM   #2
KentuckyDonkey   KentuckyDonkey is offline
You mean a bicycle speedometer? No.....it won't work.
Old 05-03-2009, 12:28 AM   #3
Why won't it work. Yes, a bike speedometer. Is there any other way to get the speed on your atv. I already know about a gps, but wanted one installed on my atv.
Old 05-03-2009, 12:44 AM   #4
LynnEdwards   LynnEdwards is offline
Yozalo, this is an intriguing idea. At a glance I don't why why it wouldn't work as long as you can enter the non standard wheel size of the quad without the software in the speedometer blowing up.
Check out the following link:
http://www.instructables.com/id/Tach...ometer-cycloc/
It is worth thinking about some more. The magnet could be epoxied into one of the holes on the rear disk brake rotor (inside the grip of the brake pads).
Old 05-03-2009, 12:51 AM   #5
Originally Posted by yozalo
...Is there any other way to get the speed on your atv...
Well there is always this. But $120 is just plain too much money.
http://www.monstermarketplace.com/Au...g2778a630.html
This one is set up for a Honda, but they sell generic ones also.
Old 05-03-2009, 02:12 AM   #6
forchetto   forchetto is offline
I have bicycle speedos on two of my monkey bikes and on my Qingqi. The first two were due to the factory speedos failing, a well-known defect on Jincheng Monkey bikes.
I fitted one to the Qingqi to get the accuracy I can not get from the factory speedo, although that works OK. These speedos can be calibrated to a great degree of accuracy and have all sorts of cool features like recording max speed attained, average speed during a run, a clock, trip meters, readings in Km or miles, etc.
I also had a Tiger Super-Six kit car, capable of hair-raising performance fitted with an auxiliary bike speedo. That worked OK.
My PGO road legal mini buggy has an electronic speedo as standard. If you look at it closer it's just a glorified bicycle instrument. It's just that the display is larger, but the technology is the same.
Some have a magnetic reed switch as a sensor, some a Hall effect sensor. Both can more than cope with the speeds that can be achieved by our sort of bike.
The only thing to watch out for are those "wireless" types where the sensor signal is transmitted to the unit by radio. They sometimes have very short range (0.5 metre) and don't work too well with the longer forks fitted to dual-sport models.
As an example of this here's a site of someone that fitted one of these bicycle speedos to a Lotus-7 type kit-car, with full details:
http://www.strangely.org/owned/bikecomp/index.html
Jincheng Monkey JC50Q-7 (two of them)
Skyteam Dax replica ST110-6 (two of them)
Zongshen ZS125-43
Qingqi QM200GY-BA Super Motard
Yamaha Virago XV1100
Triumph Bonneville SE
Qingqi QM110GY
PGO Bug rider 250 Buggy
Old 05-03-2009, 02:30 AM   #7
LOL- I'm living in the past- I was thinking of those old-fashioned mechanical bike speedos.......
Old 05-03-2009, 08:47 AM   #8
katoranger's Avatar
KD. They have come along way in bike speedos.
Yes the speedo will work. You will just need to be alittle creative to install it maybe.
The are designed for most diameters of wheels. Best way to calibrate is to measure the outside circumference of the wheel you wish to use.
Take some paint or chalk and make a mark across the tread. Then roll is on some concrete until you get two marks. Measure the distance between the marks. I think most use centimeters. Use this number to input for a size into your bike speedo.
Allen
Old 05-03-2009, 10:55 AM   #9
Yeah, it only $4 on ebay. I might as well purchase one. I never knew you have to input the wheel circumference.
Old 05-03-2009, 12:04 PM   #10
Well I just bought one. I opted for the schwinn 17 function model (I want to read temperature too). It was $14.25 total including shipping on amazon.com.
Thanks for the great idea yozalo!
Old 05-03-2009, 02:00 PM   #11
Tell me on how this mod goes. I am going to purchase the brand name ones since the chinese ones are made of poor quality.
Old 05-03-2009, 02:13 PM   #12
Maybe you should experiment with the cheap one first. It might end up being tricky to mount it and calibrate it properly for ATV use. If you get it to work good with the cheapo, then maybe get a better quality one.
Old 05-03-2009, 06:58 PM   #13
Yes, it will work since you can enter the circumference up to 999 mm.
Old 05-03-2009, 09:19 PM   #14
I hope it works for ya.....as it's a great idea, and I'm sure just about everyone would like to have a cheap speedo on their ATV.
Just found someone who tried the bicycle speedo-on-ATV thing with mixed results: http://www.utahatvtrails.com/ATVAccessories.htm
Old 05-04-2009, 12:17 AM   #15
I will definately report back how the schwinn model works.
From the pic's it looks like the spoke mounted magnet that comes standard with these things is really big and clumsy. I'll probably put my own smaller magnet in a hole drilled into the axle drive sprocket. The brake caliper holes looked like an easy solution at first but I think that it might get too hot for both the epoxy holding in the magnet and the nearby sensor.
I hadn't thought about dealing with mud before reading KD's link. I'm thinking about it now. It seems solvable to me. The cold issue is a mystery. LCD displays sometimes don't work very well in cold weather but everything else should work fine (excepting me of course, who refuses to function altogether in cold weather).
