Old 03-30-2009, 02:31 AM   #1
125 Pit Bike Oil Leak Repair
My son's 125 developed an oil leak out of the left side, and I presumed it was a shifter seal leak until I started investigating further. I figured that the leak was caused by excessive crankcase pressure, so I added a valve cap vent. That seemed to free up some power, but the leak remained.
The photos below show the removal of the flywheel, stator plate and o-ring. The replacement o-ring, part number 91301035003 was about $7 at the local Honda dealer. No more leaks.
Old 03-30-2009, 12:30 PM   #2
warrior91   warrior91 is offline
Nice. If all of us can do this once per maintenance item we will have a good tech resource for the novice or the mechanically inclined but forgetful kind.
We should sticky this as soon as you ad honda part# and engine modle...although 125 china horiz. engine says it all
'91 Yamaha Warrior- stage 2
'83 Honda ATC 70
'08 Yongjiang 125cc mx (Loncin)
'08 Yongjiang 150cc atv (Jinlong)
Old 03-31-2009, 02:01 AM   #3
I edited the post to include the part number.
Cheers!
Old 06-20-2010, 02:13 PM   #4
I'm sorry I missed this post when you first wrote it, W&G. As usual, your writeup is great, and the photographs are wonderful. If I ever get a Honda engine, I am certain I will spend a lot of time reviewing your excellent posts!
Old 06-20-2010, 03:38 PM   #5
Thanks Spud.
Old 06-20-2010, 08:28 PM   #6
Jim   Jim is offline
Me too, thanks You should add it to the tech stickies.
"Be excellent to each other"
Old 07-18-2010, 12:28 AM   #7
PULLEY REMOVAL
Is that a tool for removing the pulley?? if so does it work on all the motors???
Old 07-18-2010, 01:36 AM   #8
So far, it has worked on XR200R engines from the early eighties, a GY6 ATV and a 125 pit bike Honda clone.
Old 02-21-2023, 02:22 PM   #9
I guess this is pretty obvious, but does that gear on the crankshaft drive a counterbalancer with that chain?
-NOS 2020 KTM 250SX (2-stroke motocross)
Old 02-21-2023, 04:01 PM   #10
dirtbkr188   dirtbkr188 is offline
dirtbkr188's Avatar
No, it doesn't, Thumper, it only drives the oil pump shaft, there is no counterbalancer. At the other end is the cam sprocket
