Old 02-26-2007, 09:14 PM   #1
ambassador   ambassador is offline
Halogen Bulbs????
Anyone know where or if they have halogens as a direct replacement for an 06 GY-5, I'd like to not have to cut and splice wires... The stock light just don't cut it especially when not under power ie. sitting at a stop light...
I wanna be seen, not for my China bike but for my safety, any help would be great, thanks guys...
Old 02-26-2007, 09:16 PM   #2
And what is with the Flashlight size bulb to the right inside the headlight???
Old 02-27-2007, 12:42 AM   #3
gyjoe   gyjoe is offline
I got a halogen headlight bulb from Dennis Kirk, but I am sure they would be available at many places. I havent tried it yet, but I understand from those who have that it is a slight improvement. As for the little bulb next to it, that question was tossed around a while back, the prevailing opinion being that it is some kind of "parking light"---maybe that is something they need in China?
2006 Lifan LF200GY-5
Old 02-27-2007, 08:32 PM   #4
dlunt   dlunt is offline
Send a message via MSN to dlunt
The halogen bulb of the same wattage as stock does make a little difference. I replaced it with one, but the place doesn't carry them any more.
But more than anything, make sure it is aimed to where you like it when you are sitting on the bike.
I thought mine was aimed right, but one very early summer morning on the way to work there was this heavy, patchy fog...
I could have seen through a piece of drywall better than I could through that fog the way the light was aimed! :roll:
Old 02-27-2007, 09:54 PM   #5
mdsuave13   mdsuave13 is offline
Send a message via AIM to mdsuave13 Send a message via Yahoo to mdsuave13
hey, i AM going to find what other bulbs can fit these housings. I am determined to either A: modify the housing and wiring harness to get a 55w halogen bulb in there (then once i figure out which bulb i can get to fit, i am going to order one of the xenon hid kits from ebay for 100 bux) then i will have all the light i may ever need.....
before i get harassed about hid bulbs.. note this:
hid bulbs produce 4x more light then the average 55w halogen bulb at 6000k
hid bulbs last double the life span of ordinary 55w halogen bulbs
hid bulbs run cooler and at a lower wattage in comparison (35w compared to 55w for halogen)
hid bulbs also use roughly half the power while turned on.. its just the initial draw to fire the ballasts that im concerned about i dont think it will be a problem tho
you can get dual beam high/low hid bulbs now!
so from what im seeing, it may pay off to run the hid setup... i will have to figure out if it will work, if it does great, plus with the little bit of power im shaving off the light, i can add other crap to the bike (hardwired gps, heated grips, 12v accessory plug for charging cell phones or running a radar detector)
if anyone has anything to throw in to this equation that i havent thought about or addressed here, please feel free to make me look stupid, id rather not waste 100 bux on something that wont work because i overlooked a single detail....
My name is Justin, my friends call me Stix.
2008 Kawasaki KLR650 Candy Lime Green
______________________________
I am the official China bike registration Guru For the State of Maryland..... HA.
Old 02-28-2007, 12:50 AM   #6
Any Halogen is gonna be brighter than the POS that is in there...
Old 02-28-2007, 08:58 AM   #7
pobiker   pobiker is offline
The small bulb is a parking lamp, my 72 triumph tiger had one, beleive it or not, I lost the head light one night coming home, It actually got me home with enough to see if going slow, and sortta be seen. Better than no light at all when its 2 am and there is no parts store open, especialy one that would have a Lucas bulb in stock.
Old 02-28-2007, 12:07 PM   #8
CathastrophiX   CathastrophiX is offline
There are 35, 45 and 60 watt halogen and "standard" bulbs with Ba20d socket. I´ve changed to a 45 watt.
"Failure is always an option!"
Qingqi QM200GY -06
Old 02-28-2007, 02:15 PM   #9
Ditto on the 45W as seen in the Cross Ref Parts thread.
2008 Jonway MC-70-150
2007 Roketa DB-07B (RSM-200E)
2006 Roketa DB-07A (RSX-200E)
Old 03-01-2007, 07:12 AM   #10
stixx3969   stixx3969 is offline
On my Roketa, the small bulb is actually the low beam light.
Old 03-01-2007, 08:45 AM   #11
i'm thinking i may just upgrade the whole number plate and headlight to a better equipped setup.. the factory setup may not cut the mustard...
we'll see tho, im going to call around and see what i can find out.
Old 03-01-2007, 08:34 PM   #12
One thing to be aware of is that most of these Chinabikes don't have very strong charging systems.
I wouldn't go over a 45 watt unless I regurlarly plugged into a tender.
Of course if you change the rear light out for an LED then you have some juice left over for a stronger front.
I remember reading a few posts here and elsewhere about higher wattage bulb draining the battery evertime they rode.
I believe the bikes that have the batteries in the back have smaller batteries too. The ones under the seat are little larger. Maybe a little more electrical umph?
Bright lighting is an underrated saftey feature.
A lot of my gear is black so I want the bike to stand out.
Old 03-01-2007, 09:16 PM   #13
I was going to go with a 60 watt bulb, doesn't the engine recharge the battery while running ie. alternator?
Old 03-02-2007, 11:50 PM   #14
sheadouglas   sheadouglas is offline
I think they have a magneto, or something like that. Not sure if it has the same purpose as an alternator or not? Someone fill me in. Maybe it doesnt recharge your battery while it is running?
Old 03-03-2007, 01:26 AM   #15
it has a stator/magneto, it does the same thing as an alternator, but produces MUCH less charging power then an alternator.. i need to figure out if ours is good enough to power such a light... or even an hid setup.. i dont know how it would work at idle, considering the regular 35 watt bulb flickers...
