Old 03-12-2009, 04:36 PM   #1
pezgoon   pezgoon is offline
Timing
Anyone know how to advance the timing on a lifan 200cc 163 fml engine?
Old 03-12-2009, 06:24 PM   #2
markwr35   markwr35 is offline
its all in the cdi i think. you can buy a mod cdi from ebay
gy 125
gas gas 250
aprillia rs125 (my baby) Now sold to buy
my sons xr 125
If it works leave it or better weld it
Old 03-12-2009, 09:49 PM   #3
katoranger's Avatar
Some have modded the pickup coil to advance timing. You slot the mounting holes so that you can slide it over slightly.
Allen
Old 03-13-2009, 04:17 AM   #4
czowner   czowner is offline
Allen
I was just about to post when I read this, just done it (slotted the holes that is). A rough calculation says you get about 2.5/3 degrees more advance. I see an improvement over the whole rev range, she now pulls 70+ mph on the flat. Idles like a dream from a cold start and fairly plods up hills, at times I'm using a gear higher than before.
Jonathan.
Old 03-13-2009, 04:40 AM   #5
DDG1976   DDG1976 is offline
Send a message via Yahoo to DDG1976
Pictures, I need pictures!! I would like to do that to mine.
I have all of soberday to satur up!!
Old 03-13-2009, 06:15 AM   #6
BillR   BillR is offline
From an older thread.
Found a couple of pics here:
http://www.chinariders.net/modules.p...iming&start=45
No, I haven't tried any of these mods. Interesting though.
Bill
Old 03-18-2009, 03:37 AM   #7
Over the last 2 tankfulls fuel economy seems to have improved by about 5 miles a tank.
Jonathan.
Old 03-18-2009, 04:08 PM   #8
Ma77   Ma77 is offline
I played around with the ignition timing on my first bike (along with other things as it was a 50cc, 80cc and finally a 125cc ) and even a small change to the timing made a huge difference so may be worth a try
Old 03-21-2009, 10:22 AM   #9
JoJo   JoJo is offline
Okay? Still confused. I was replacing the gasket seal because it was leaking (I used that great stuff spray gasket...we'll se how that works??) and decided to also do a valve adjustment (done before) and timing adjustment (not done before). First off the auto tensioner was not properly put together and it took me some time to figure out how to wind it up first and then place it back into the engine, but it now works properly. Second. The timing mark is spot on when it's TDC, but when I assembled the chain tensioner it moves the mark to the right about 1/2 in. I was trying to figure out how to align it properly, but you guys are saying that there is no easy way to do this?? I really have to drill some hole in the pick-up coil mounting plate and rotate it clockwise or counter clockwise if looking at it?? I really thought that this would be an easy adjustment. Not that cutting some holes would be that hard?? gonna skip it for now.
dahhh!! Pimpin Ain't Easy!!!
Old 03-21-2009, 04:26 PM   #10
Yeah am a bit stuck on that aswell Do you move it up or down to be simple
gy 125
gas gas 250
my sons xr 125
Old 03-21-2009, 04:44 PM   #11
forchetto   forchetto is offline
To advance the timing the sensor or pick-up coil is moved in the opposite direction to the normal rotation of the rotor. Not 100% sure, would someone confirm this?.
Jincheng Monkey JC50Q-7 (two of them)
Skyteam Dax replica ST110-6 (two of them)
Zongshen ZS125-43
Qingqi QM200GY-BA Super Motard
Yamaha Virago XV1100
Triumph Bonneville SE
Qingqi QM110GY
PGO Bug rider 250 Buggy
Old 03-21-2009, 08:29 PM   #12
Correct. So the sensor "sees" the lump on the rotor sooner.
Jonathan.
Old 03-22-2009, 07:02 AM   #13
Okay so 2.5-3 degrees counter clockwise should do it? Pobslly will try nect oil chanage. Tnx
Old 03-22-2009, 07:16 AM   #14
Depends on which side of the engine your magneto is situated. On most bikes it's on the left side of the bike/engine, so assuming the crank runs forward (anticlockwise when viewed from the side), then the sensor has to be moved clockwise.
Zongshen ZS125-43
Qingqi QM110GY
Old 10-18-2020, 02:49 PM   #15
magnus   magnus is offline
did u find it out? i have the same problem with my lifan 200cc engine, it using so much gass and after like 2 hourse of riding the oil was super black, and it dosent like to start at all, but when its worm it fire right up.
