Alternative larger fuel tank.
In one of my recent browses through flea bays petrol tanks I came across this:
![]() It's a Hyosung RT125 Karion. It looked about right, and it was! ![]() If you're not a welder you could just drill some fresh holes in the rear mount and twist it to about 30' from the horizontal. ![]() The front mounts drop from the stock tank mountings, I welded a pin for the bobbin (a yamaha item), non welders could improvise with a countersunk bolt? ![]() The tank had no tap, and the original Hongdou tap was too long and fouled the cylinder head. The only Chinese tap I could find at the breakers was this short one, so there's been some careful filing to make it fit. ![]() The finished job, total cost £23 ($35). Without Googling how big do you think the tank is? It's deceptive. Jonathan. |
gas tank
does it hold more fuel than the stock tank?because that would be a plus for these lifans,a little more miles per fill up
Probably 1.7 gal.
Chinabikeless |
Nice work :!: , I wonder if any of the desert tanks offered could be made to fit now.
#5 | |
Jonathan. |
#6 | |
I wonder if the new Hi-Bird 5 gallon tank, or the Shineray 5 gallon tank will fit the majority of these GY-series bikes. That would be something interesting--the gas would last longer than the bike!! ![]() |
![]() I can't see anything bigger fitting very easily (or looking "right"), unless you want to start changing the seat as well. There's not much room along the top frame tube. Jonathan. |
