Old 02-15-2009, 07:05 AM   #1
truthfriend7   truthfriend7 is offline
My Bike's Overheating, Why? (sorry for the honda question)
Let me apologize for asking a question about a non-china bike. I just feel more comfortable asking you guys (being a former china biker myself) and the bikes is a similar design. It's a honda xl600 single cylinder, air-cooled engine with overhead valves. I recently had it bored out with a new piston and lapped the valves.
It runs and drives okay, but the spark plug looks too hot. Also I'm only getting about 20 miles-per-gallon. My understanding is that I should be getting twice that. So it must not be a fuel mixture issue because I'm burning through the gas. There's no fuel leaks I can see. I checked the timing and it's perfect. I did notice that one of the intake valves was too tight on the clearance but that's it. Do you think that's what was causing this or something else?
Thanks for your help, and don't feel like you need to waste any time looking for an answer. Just if any of you mechanics have something off the top of your head that helps I appreciate it.
Old 02-15-2009, 07:56 AM   #2
Who did the reassembly ?
Old 02-15-2009, 09:46 AM   #3
VinceDrake   VinceDrake is offline
If it's really recent, the engine could just be that tight. (i.e. between the rings and the bore)
A rebuilt engine creates a pile of heat for the first few hundred miles, until things are mated correctly, and more fluid. Also, all that extra friction does destroy fuel mileage.
Personally, on a fresh 4 stroke motor-cycle engine I like to throw some 2 stroke oil in the fuel, and a bottle of EOS (A ZDDP additive) just to try to soothe the hot spots, until things get broken in some...
--Vince
"Sometimes it is better to say nothing, and let people think you're an idiot, than to open your mouth and prove it."
Old 02-15-2009, 10:30 AM   #4
katoranger's Avatar
We now have a new forum for off-topic bikes so I will move this there.
I leaning toward the really tight engine.
Old 02-15-2009, 11:26 AM   #5
I'm wondering who put it together and if they set the rings with the right clearance or maybe didnt lube it up right on reassembley.
Old 02-15-2009, 04:39 PM   #6
Oh thanks, I didn't realize there was a new forum for non-china bikes. Cool.
Actually I did the rebuild. But I do admit this was my first one. I had a machine shop bore the cylinder 1mm over. I gave them the new piston so they could match it perfectly. I did it by the book and also had some help from an experienced guy too. The end gaps and position of the rings were perfectly in spec. I did wipe oil in the bored cylinder too. However, I didn't know that a new top end would cause hot running and poor fuel mileage though. 20 mpg's seems pretty bad to me. Do you think that's a little too low for a 600?
Old 02-15-2009, 05:24 PM   #7
Well, It's a dog of a different stripe, but when I did the top end of my RD the last time (Number 10 at least) I was down to about 15mpg for the first 250 miles or thereabouts. (Takes a really long time with only a 2 gallon tank to get anywheres...)
New top end, new rings, etc. I wouldn't say 20 mpg is unreasonable for the first couple of tanks...
--Vince
Old 02-15-2009, 09:26 PM   #8
--Vince
What fuel mileage did you get after the initial 250 break-in period? Did it cool off after that as well? I'm wondering if I need to adjust mixture at mid throttle to keep the plug from getting so white in the meantime. But I'd rather not if it's going to work it self out and start running cooler. I like the 2 cycle oil idea. I'll have to try that next tank. Maybe a 60 or 70 to 1 ratio? Thanks.
Old 02-15-2009, 10:18 PM   #9
The RD (a 2-stroke Yamaha) Slowly improved from there, about 3mpg more per tank, each tank following. Just the first few sucked completely, and yes it did cool down more and more with the passing of the miles. Each of my china-machines exhibited the same symptoms when new
Since we're on the subject of break in, there's 2 schools of thought, slowly and gently, and ride it like it's going to be ridden. I usually start with the first, and end up doing the second when my throttle hand gets the best of me.
When I light up a new one, I'd say about a 70:1, just enough so there's something there for the valves... But that's just me, others may differ...
(And lots and lots of oil changes... Gotta get the crap out of there...)
--Vince
Old 02-16-2009, 09:26 AM   #10
Yeah, I read a post recommending the motoman break-in method which is basically the "run it hard" school of thought. I did that for the first few miles but then my tale pipe caught on fire. I wondered why the motor was bogging down and why people seemed to be staring more than normal. Just too much crud built up in there over the years. In hindsight, I thought is was kind of cool to be riding around with a big old flame out the back. But just not practical.
I wonder if the effects of a new top end would be the same on a 4 stroke as a 2 cycle? I don't see why it wouldn't. That would be great if the bike doesn't need anything. The motorcycle veteran I talked to the other day thinks I need to check out the ignition timing.
