02-19-2007, 09:57 AM | #1 |
Speedometer cable broke
It broke, the inner cable. Right below that actual gauge you look at. So I will be contacting XXX motorsports for a replacement, unless anyone has one laying around?
Roketa DB-07A 200cc |
02-19-2007, 10:49 AM | #2 |
Yep, mine to, same place
02-19-2007, 11:34 AM | #3 |
I went around to the local dealers to see if they had on, but they didn't, so I guess I will put in a warranty claim.
02-19-2007, 04:21 PM | #4 |
Same here only 150 miles on it. if it had a gas gauge Id skip the spedo probably want last any longer next time hmmm
02-19-2007, 04:58 PM | #5 | |
02-20-2007, 08:38 AM | #6 |
Really? Through who? I contacted Goldenvale about some parts similar to this and they said they were not warranty parts.
Also, there must be a replacement that matches one of the big 4. Has anyone checked their local shops? These aren't "special" speedometer cables. It has to match something that is already in production IMO. Let us know Jason
02-20-2007, 12:33 PM | #7 |
fatboy....I agree, it seems like there is something else that might work....
many jap bikes used the slotted end/one end,...and squared end,other end, inner cable...........and I would like to see a cable a couple inches longer..... I'm working on possible matches now,...will let you know if I find something.
<div>Steve 2006 Roketa DB-07A/RSX-200E 2008 Roketa 250 Scooter 2019 Brozz 250 |
02-20-2007, 01:34 PM | #8 |
JC Whitney has a universal speedometer cable that works on my viva. You just cut it to size and crimb the correct fitting on the cable. Works great and it fit perfectly. I am not sure how to get the link on here put here is the address. http://www.jcwhitney.com/autoparts/P...edometer+cable
Hope this helps. Ride hard and have FUN!!! |
02-20-2007, 02:53 PM | #9 |
To add to what Rachel said, the replacement is heavier and more flexable and should last longer.
Love from the Arizona High Desert |
02-20-2007, 03:16 PM | #10 |
Yes, this is the kind of stuff we need in the Cross Reference Parts List. I will add it.
Speedometer Cable (cut to fit) http://www.jcwhitney.com/autoparts/I...D:100000146589 Jason
02-20-2007, 09:36 PM | #11 |
excellent, just want i needed, mine as well go ahead and order me on...probably get here before the stock one will
02-20-2007, 09:38 PM | #12 | |
02-20-2007, 11:26 PM | #13 |
Is it just me or are the speedo cable routed in a terrible way? Lots of stress on that cable.
02-21-2007, 07:30 AM | #14 |
hi....its my thinking that the cable is too short to be routed the way it is,..........and yes, its under a lot of stress..........
the counter needs to be directed more to the rear, so the cable connector is straighter up,.....or a longer cable is needed it looks like the DB-07A is one of the few that have the cable positioned like it is?....dont know that for sure, but from pics, it looks like the other 200 models have the cable more to the rear
02-21-2007, 10:04 AM | #15 |
Yeah if you really look at the layout of the bike the cables and brake line are crossing each other. It seems as if the front forks should be turned around, but that would shorten the wheelbase a bit.
