Thread Tools Display Modes
Old 01-16-2009, 06:13 AM   #1
craisin   craisin is offline
can you tell me if its easy to transplant gear indicator led
well the switch gear in the gearbox can it be install into a different block that seems to have holes to acomodate them if you can sweet lifan engines
Old 01-16-2009, 09:03 AM   #2
Sorry brother, I didn't understand the question.
IronFist
The "chain" of command is used for beating spammers.
Old 01-16-2009, 10:02 AM   #3
Cal25   Cal25 is offline
If you are asking if you can put a gear indicator on a bike that did not come with one, Yes it is possible if the bike has the wiring for it. Someone on here put a Lifan display on a HiBird if I recall.
Others may be of help as well.
Old 01-16-2009, 05:40 PM   #4
thanks Cal25 i will check it out
Old 01-16-2009, 05:48 PM   #5
yeah right the switch gear on that other project was in the other motor and they just swapped the plug Cal25
Old 01-16-2009, 10:05 PM   #6
i do have another parts engine that lost its head to fix my 48cc engine. I just bought a 49cc engine its had the ignition pick-up smashed off in a chain break smashed thru the cover too . the parts engine is a 110 cc Loncin that most likely had a chain break too. the missing ignition components i can pillage off the 48cc. Bloody Kiwis :arrow: :roll:
Old 01-18-2009, 11:25 PM   #7
ive decided its not worth while the 48cc still goes and if i pull another 90cc elecktrics from one with a broken crankcase
