Old 12-01-2008, 03:09 PM   #1
Dragon   Dragon is offline
JB Weld v. Silver Solder
My clutch cable broke at the lever. I will try to fix it. I heard silver solder is really strong, and I have some and a solder iron. Should I use JB Weld or silver solder?
Chinabikeless
Old 12-01-2008, 03:28 PM   #2
DDG1976   DDG1976 is offline
Send a message via Yahoo to DDG1976
I'd have to go with a new clutch cable, unless you just can't find one.
http://www.hooperimports.com/product.aspx?pf_id=CCL-V
I have all of soberday to satur up!!
Old 12-01-2008, 06:33 PM   #3
warrior91   warrior91 is offline
Drill out old cable from tit.
Insert clean cut end of cable ...fill with silver solder...readjust cable at clutch end...
'91 Yamaha Warrior- stage 2
'83 Honda ATC 70
'08 Yongjiang 125cc mx (Loncin)
'08 Yongjiang 150cc atv (Jinlong)
Old 12-01-2008, 06:35 PM   #4
The bike only has 5000 chino-miles when the cable broke today. I think I want to fix it right or replace it with higher quality cable, not another chino cable.
Chinabikeless
Old 12-01-2008, 06:38 PM   #5
Too bad that the tit fell out, and I can't find it. I plan to make a tit out of a bolt.
Chinabikeless
Old 12-01-2008, 08:19 PM   #6
Jim   Jim is offline
Chino?
Cables break, it isn't limited to China bikes only.
"Be excellent to each other"
Old 12-01-2008, 08:28 PM   #7
Here is the cable after making a new nipple and soldering it onto the cable with silver solder. I pray to Lord that it holds, as this bike is my only mode of transportation.
Chino is Spanish slang for Chinese.
Chinabikeless
Old 12-02-2008, 07:55 AM   #8
Q   Q is offline
The correct way to solder a cable terminal is to put the cable through, bend the ends of the individual wires outward like flower petals, then solder. Regular 60/40 solder works fine.
Q
Old 12-02-2008, 08:35 AM   #9
Jim   Jim is offline
That looks good
Old 12-02-2008, 09:31 AM   #10
Q
Q, I wish I had read your reply before I soldered it. I didn't do the flower-petal method. I would redo the cable using this method, if the cable is long enough. It's not. It's just barely long enough as is. I think I'll buy a new cable (only the inside part) and solder that using the flower-petal method.
Does anyone know where I can buy just the inside cable, with a steel ball at one end?
Chinabikeless
Old 12-02-2008, 11:24 AM   #11
Jim   Jim is offline
When my dad was fixing his on his Victory, he found the cable at a lawn mower repair shop I believe.
Old 12-02-2008, 09:23 PM   #12
Q   Q is offline
Most if not all motorcycle shops have bulk cable, cable housing, and terminals. Just take your old cable in and get the correct stuff, then solder it up. Piece of cake. I've made hundreds of cables over the years.
Q
Old 12-02-2008, 11:19 PM   #13
jayg   jayg is offline
Chino is spanish slang for China...well my RL chinos are made in China anyway.
Old 12-03-2008, 12:38 PM   #14
winwun   winwun is offline
How in the world did you get silver to melt using an iron ?
On large stuff, I have to put a little O-2 in with the propane in the torch, but with small stuff, I can usually get the silver to flow if I use MAP gas, but an iron . . .? :?:
If everyone picked up a couple of pieces of litter, pretty soon there wouldn't be ANY, and wouldn't THAT be nice ?
Luke, 11: 21
Old 12-03-2008, 01:47 PM   #15
I use a big, 60 watt iron and flux. Without the flux, the solder won't flow.
I got the supplies from a RC model airplane shop.
Chinabikeless
