Old 11-19-2008, 08:36 PM   #1
chriseck   chriseck is offline
Front brake not releasing
The front brake lever on my 2005 Roketa RSM-200 enduro is not releasing back after the brake lever is squezed.I have bled the line twice out thru the bleed screw with only short term results til it happens again.The brake lever feels sloppy and is slow to return.When I removed the brake reservoir cover the first time their was a half moon sliver of metal in the fluid.Is my only option to order the complete system for $114.00 ?
Old 11-20-2008, 03:29 AM   #2
china_parts_canada   china_parts_canada is offline
Send a message via MSN to china_parts_canada
Re: Front brake not releasing
Hi there, Sorry to hear you are having such problems with your brakes.
By the sounds of things you may only need the master cylinder but it is hard to say without being the one working on it.
I am a parts guy in Canada and I likely have the whole assembly you would need for about $75.00 if you want to send me a picture or two I can tell you for sure.
Cheers,
Art
Old 11-20-2008, 08:19 AM   #3
katoranger's Avatar
Sounds like you need a master cylinder.
That price sounds really high too.
Allen
Old 11-21-2008, 09:46 AM   #4
red2003   red2003 is offline
Just to be clear, you are saying the lever doesn't return ?? Have you tried loosening the bolt to make sure the lever isn't being pinched too tight?? If that's not it, then check on eBay. Any master cylinder with the same size banjo fitting will work. I'd look for something off a Japanese MX / enduro bike. You should be able to pick one up for < $10.00!
Old 11-23-2008, 07:49 AM   #5
I will look around as you suggested and will fall back on the guy from canada if need be.
Old 11-24-2008, 09:20 AM   #6
katoranger's Avatar
Also make sure it is a standard 7/8" bar mounted master cylinder. This is common, but a few bikes had 1" bars.
Allen
