09-23-2008, 04:57 AM | #1 |
cylinder head rework
On my last ride I broke off the upper exhaust pipe stud,flush with the head.Since I am having the stud removed at the machine shop,should i have the head milled while it is off? How much should be removed and what would the benefit be? It currently has a 9:1 compression ratio.
Thanks again all :?: If the stud cannot be removed,I am having a hard time finding a replacement head........ :x
Lifan LF200GY-5 |
09-23-2008, 07:48 AM | #2 |
I'm not to sure about the compression ratio, but the stud extraction is a fairly simple task for a machine shop, especially with the low carbon steel the Chinese use for their fasteners.
Next time, consider a drill bit and "Easy-out" screw extractor, available for a few bucks at the hardware store...You will probably save a few bucks, and get it done faster and easier, without removing too many parts. Just my humble opinion, Tigertamer
07 H-D XL883C 06 LF 200GY-5 Yin and Yang CAUTION Obey The Traffic Regulation. Always Wear a Helmet. Don't Ride After Drinking Wine. Before Operation, Read The Owners Manual Carefully. |
09-23-2008, 12:22 PM | #3 |
If you haven't already pulled the head, don't. The machine shop can get the stud out on the bike. No problem there. I would suggest you DO NOT have the head planed. The increased performance (if any) would not outway the need to run on premium gasoline afterwards.
09-23-2008, 03:49 PM | #4 | |
Use a left hand or reverse drill bit on broken fasteners. You'd be surprised at how well they work. A Dremel tool is always very handy too. Sometimes you can slot the end of the broken bolt enough to turn it with a screwdriver or tap it loose with a punch. As for machining the head... unless you have used plastigauge to check the clearance between the valves and the piston, don't even think about machine work. Sometimes even low compression engines will have very little clearance between the piston and open valve. Then there are other issues like the timing chain or gears on the OHC engines... I think the valve train of an OHV engine would be fine with some mild decking or milling of the head. I have thought about doing the same to my engine, and I think it's a very doable and worthwhile mod. But it's like the old saying, "Measure twice, cut once.". If you could bump the compression up to something like 11:1, port the head, add a pumper carb of about 32mm and a decent exhaust, I could see getting 22hp or more out of a Chinese engine. (But would it last?) |
09-23-2008, 04:16 PM | #5 |
I wouldnt shave the head either unless you plan on going thru the whole engine and reworking all of it.(not worth it in my opinion)
I havnt tried these but I may the next time I need to extract a bolt. ALL-IN-ONE-extractor Most of the time I can just weld a nut back on the nub of the bolt and with all the tools needed right there at the ready I can weld the nut and then wait until I think it has cooled enough and just turn the bolt out and on the bigger bolts the impact makes it even easier. Of course you really have to watch what is around it that can be damaged by that much heat. |
09-23-2008, 06:36 PM | #6 |
Knothead:
"A Dremel tool is always very handy too. Sometimes you can slot the end of the broken bolt enough to turn it with a screwdriver or tap it loose with a punch." Once again Knothead, I've done the exact same thing.
IronFist ___________________________________ The "chain" of command is used for beating spammers. ___________________________________ |
09-23-2008, 09:09 PM | #7 |
You can also use the Dremel to clean off all the carbon in the combustion chamber.
Wayne Wildfire WF300-SP |
09-24-2008, 10:18 AM | #8 |
I've worked close to 1000 pounds of soapstone with a dremmel 8O My shop is set up like a dentist's office.
09-24-2008, 04:35 PM | #9 | |
09-24-2008, 06:44 PM | #10 | |
09-24-2008, 10:41 PM | #11 | ||
http://www.chinariders.net/gallery2/...avId=xddeba81c
09-25-2008, 08:16 AM | #12 |
You did the right thing taking it to a machine shop. It'll save you money and grief. Easy-outs should be banned for any engine work. If a bolt is seized so bad that it snaps from the extraction torque the chances of successful removal with an easy-out are very slight. What often happens is the easy-out breaks off in the bolt you're trying to remove and now you have a piece of hardened steel between you and the softer bolt you were trying to remove.
Case in point: http://nbdsc.ca/forum/viewtopic.php?...broke&start=15 Learn from our mistakes. Easy-out = EVIL.
Frostbite "The beatings will continue until moral improves" |
09-25-2008, 10:21 AM | #13 |
A year ago I had a problem with a broken bolt, I tried the easy out from CrappyTire. I had no luck with it at all. I too got frustrated and went at it with the knothead method. It was out in 10 minutes and there was no damage to the case. I'm too city-fied to have a mig or tig or even an A/O torch.
Since the head of the screw was gone, I would have pulled the other 5 screws, pulled off the side case I was working on, and exposed the broken screw. From there I could have got at it with a set of vice grips. I think it really matters where the screw broke and how much material there is to work with/ weld to. I did use heat, and lube, and I rapped it with a punch. If I didn't get it out myself I would have taken it to the shop. Not much else I could have done. Hypocratic oath, "Do no harm." The last tool in my kit is always to take my bike to the shop
09-26-2008, 04:28 AM | #14 |
SORRY AGAIN, for giving advice that has worked for me many times in the past! 8)
Don't try this at home, KIDS, Tigertamer
09-27-2008, 12:45 AM | #15 |
Just to jump in on the Easy-out thing. I hate easy outs. They break, they strip, they suck, on and on ad-infinitum. *BUT* If you can drill the right size hole, a decent Torx Socket, is about the best easy-out money can buy.
Better grip, and less likely to snap. Just hammer it in a little bit, and twist with ratchet. Works like an easy-out should have. --Vince
"Sometimes it is better to say nothing, and let people think you're an idiot, than to open your mouth and prove it." |
