09-22-2008, 03:37 PM | #1 |
Swing Arm Danger..
Wow.....so I take my HSUN 200GY to my bros shop this morning to charge the battery elec starter wont work, I notice on my way there a mean slip kick out from the rear tire, should have pulled over but it sort of passed, so I took it on, wow had some major control issues on the way there, my brother was working so I just went ahead and charged the battery and he helped me tighten a few things and fix the license plate bracket, he took it for a little spin and I noticed the back tire wobble a bit, we checked tire pressure, decided it was good to go so off I went, man rear tire was shakin, anyways I pull to a red light and the guy behind me says your rear tire is not in line with your frame.shi7.so I pull over whoa the tire was way off to the right, the tire was on and did not wobble but I could turn it by hand when parked, I started thinking that the frame cracked, took it home when I got there I discovered the swingarm bolt that attaches it to the frame lost its nut and let the right side of the swingarm completely loose from the frame, Im lucky the bolt didnt completely fly out, anyways hammered it back and bolted it back on..something I will be checking before every ride! 8O
09-22-2008, 03:55 PM | #2 |
I'd use a whole tube off red loctite too! That's scary considering since my sprocket change I can get my GY-5 up to 80+.
I have all of soberday to satur up!! |
09-22-2008, 04:13 PM | #3 |
Nick put some loctite on too, Ill have to look into a whole tube myself.lol......seriously, I know to tighten it before every ride now and to keep an eye on it, on my vacation at the end of October Ill be down at my brothers shop to tighten what ever else might fly...we also re-hosed the emmissions system where the hose got so hot it blows, my bike seems to run smoother with it on!
09-22-2008, 10:52 PM | #4 |
I'm glad you got it home safely and fixed it with minimal effort.
Just be careful about tightening every bolt you can find. Unless you've replaced them all with stronger bolts, you may end up snapping something. And I don't just say that for your benefit. Anyone who reads the thread needs to understand the risk. I wish we could tighten that loose nut behind the wheel! :roll:
2008 American Lifan LF200 GY-5 (930 km) - Sold 2007 Kawasaki EX250 - Sold 2006 Kawasaki EX650R - My new ride! 2005 Kawasaki EX250 - A new project |
09-23-2008, 07:13 AM | #5 |
This problem seems to be cropping up way too frequently. :evil:
Since the failure is most definitely, CATASTROPHIC, I would suggest to the administration to make a sticky or start a safety related forum! Thanks for listening, Tigertamer
07 H-D XL883C 06 LF 200GY-5 Yin and Yang CAUTION Obey The Traffic Regulation. Always Wear a Helmet. Don't Ride After Drinking Wine. Before Operation, Read The Owners Manual Carefully. |
09-23-2008, 08:30 AM | #6 |
It seems to be an issue with the HSUN bikes. Everyone should check there bolts. Espicially anyone with a HSUN bike.
Will make this a temp sticky for right now.
09-23-2008, 08:41 AM | #7 |
Hats Off, to Katoranger, for taking swift action to get the word out :!:
Thanks, Brother, Tigertamer
09-23-2008, 06:43 PM | #8 |
Absolutley be very cautious, my bike is a roughrider, but Im used to it, in fact the bolt probably loosened weeks ago as I was experiencing tire wobble for quite some time, I was constantly checking tire pressure assuming that the tires were loosing air, not the case so I wrote it off as a chain issue.I dont have the experience or money to attack at any problem the bike suffers right away so it persisted, I should have flagged it when I saw the tire wobble a bit when I saw my brother take off on it...the road to work has been under heavy construction for over a month.new pavement so the bike endured many miles on chewed up pavement, hard on any machine, my advice dont let a tire wobble go unfixed or yes catastrophe, although the swingarm bolt was over looked in my case and I should have kept my eye on it, very important!
09-23-2008, 09:14 PM | #9 |
Was there any grease on the bolt?
I know mine snapped a week and a half ago while doing 120km/hr and didn't have any grease on it. I believe that is a common finding among others. I replaced it with a slightly bigger diameter and much stronger bolt that was machined down to match the originals size. Couldn't get a match at HD Supply here in Ontario.
Riding a blue plated HSUN 200GY (Otherwise know as a ULIKE 200GY, SUNL 200GY or a VIVA SX200S), a 2010 Gio Mini Hummer 110cc ATV, 2010 Gio T3 Rebel ATV, and a 2002 Kawasaki KLR650, 70cc Katera dirtbike, and a 49cc GIO dirtbike...so far! |
09-24-2008, 08:51 AM | #10 | |
TT
09-24-2008, 12:37 PM | #11 |
Thanks for the tip Squish.there was very little grease on the bolt in fact!
09-27-2008, 12:15 PM | #12 | |
'91 Yamaha Warrior- stage 2 '83 Honda ATC 70 '08 Yongjiang 125cc mx (Loncin) '08 Yongjiang 150cc atv (Jinlong) |
09-27-2008, 01:39 PM | #13 |
I think I'll drill the end of my swing-arm bolt and put a castellated nut on w/cotter pin properly installed . . .
You guys dodged a BIG bullet, and I'm not feeling a bit bad about riding your coattails on this one . . .
If everyone picked up a couple of pieces of litter, pretty soon there wouldn't be ANY, and wouldn't THAT be nice ? Luke, 11: 21 |
09-29-2008, 08:56 AM | #14 |
wow i'm gonna check that right away, i've been feeling the wobble for the better part of two weeks, i just figured it was nothing YIKES!
09-29-2008, 11:12 AM | #15 |
Been checking that nut every preride check for some time. Seems to be staying nice and snug on my HSUN Viva. Haven't changed the Zirc to get any grease in there. :oops:
Don't like time bombs either, better replace that bolt with a hi-strength one and a castlenut, too!! :wink:
Wayne Wildfire WF300-SP |
