08-25-2008, 08:24 AM | #1 |
Bike wont start in neutral any more. Any way to fix this?
I have a gy200-2. It used to turn over and start in neutral with the clutch out.
Now the only way I can get it to turn over is to pull the clutch in. This is not a big problem but it I would still like it to fix it if it is possible. |
08-25-2008, 10:21 AM | #2 |
Look at your wire ball behind the headlight for the diode and see if has unpluged or a wire broke.
Mark |
08-25-2008, 11:21 AM | #3 |
My clone will only start with the clutch pulled in. Sounds like maybe it fixed itself?
2005 Diamo LS200 2009 WR250R 2010 Motobike Hyper |
08-25-2008, 10:06 PM | #4 |
Mine won't start without the clutch pulled in. It's a safety thing to keep it from starting in gear. I agree with monkeyboy, sounds like it fixed itself.
2006 Jetmoto TT200GY 2000 Suzuki VS800GL |
08-25-2008, 10:42 PM | #5 |
The correct 2 wires actually came together, well that would be a first 8O
My wires don't attach, they detatch.
IronFist ___________________________________ The "chain" of command is used for beating spammers. ___________________________________ |
08-26-2008, 12:54 AM | #6 |
Same here. The latest is no brake light with the front brake, but works fine with the back, lol!
08-26-2008, 01:00 AM | #7 |
Monkey those are two different wires. Check, (don't smash with the hammer) the on off switch at the front break handle, it might not be engaging properly. I needed to use a dab of JB on the handle to make the switch close when the handle was released. Might be something else but that was my problem.
08-27-2008, 05:01 PM | #8 |
I have bypass the clutch safety switch so my bike will now start in gear. The wire broke off the diode so I just disconnected it and the clutch switch wire was pinched during assembly. I just spliced those together completing that circuit.
WARNING. Make sure bike is in neutral before starting or clutch is in. Allen
