Old 07-28-2008, 08:56 AM   #1
jwe   jwe is offline
Exhaust Leak Help
I did a search and didn't find this exact problem.
I posted this under my original Topic but don't think it was noticed.
I had noticed some black stuff on the right side of the starter before, but
had attributed it to chain lube "spraying" off. However, tonight I noticed
the clamp around the muffler where the 2 sections meet was a little loose
so I tightened it up, started the bike and there is exhaust shooting
out. It is shooting out right at the motor and starter.
How can one fix this??
08 AL LF200-GY5
Old 07-28-2008, 05:35 PM   #2
Kawazacky   Kawazacky is offline
Mine does this too. It helped a little when I put a new gasket in and coated it with Ultra Black RTV sealant, as Bruce from EJ Cycles suggested. I think it's a common problem with these bikes.
You can also get a hose clamp and tighten up on the pipe behind the stock clamp - double your chances of stopping exhaust blowing through.
Old 07-28-2008, 07:01 PM   #3
Can you make a flange from a softer, thin metal?
IronFist
The "chain" of command is used for beating spammers.
Old 07-28-2008, 07:47 PM   #4
To bad I cant find something like this (EasySeal Stainless Steel Clamp) to fit as I have thought this would be very useful at that exhaust point.
Sadly they dont seem to come any smaller than 2" diameter.
Old 07-29-2008, 09:17 AM   #5
jwe   jwe is offline
What is the gasket you are referring to?
I haven't taken it all the way apart yet so I am not aware of what is there.
Thanks everyone for your input. I will see what I can do.
Woohoo, not a newbie anymore 8)
Old 07-29-2008, 02:06 PM   #6
forchetto   forchetto is offline
Removed. Error.
Jincheng Monkey JC50Q-7 (two of them)
Skyteam Dax replica ST110-6 (two of them)
Zongshen ZS125-43
Qingqi QM200GY-BA Super Motard
Yamaha Virago XV1100
Triumph Bonneville SE
Qingqi QM110GY
PGO Bug rider 250 Buggy
