flushmount turn signals
Anyone out there install a set of flushmount signal lights? I am thinking I would like to make my own or buy a set or something. One of the rear ones is broken after an offroad adventure (just a note the tusk bark busters do an excellent job of busting rock as well).
I am thinking some cab mount lights might work? I want cheap and something that won't break next time I fall because I will fall. It is just the way I ride! Thanks, Glenski |
http://www.1tail.com/sa/cart/category.asp?cg={7C408199-F011-4CD4-A109-636F5004E0CF}
Quite a few choices out there, Hope this helps.
I changed mine to flush mounts. They work well.
I got them at the local dealership for around $18. You can find them on ebay as well. Just do a search for "flush mount turn signals". There are many different kinds and sizes. I had to drill two holes and use a couple of rubber washers I had as spacers so they would sit flush. you can see what I mean in this pic. Hope this helps. ![]() Left rear signal... ![]() Right rear signal... ![]() With the tail section installed... ![]()
2000 MZ Baghira |
Thanks, those look nice on your bike. The tail section of my Lifan doesn't really look like that though. I went out and had a look around tonight. I am not even sure where you would mount them on a Lifan such that they could still be seen with luggage on.
Check with a truckers chrome shop.Lots of choices and most LED's are usually $20.00 or less.
yamaha vstar 650,unknown chinese 4 wheeler,johnny pag 250 spyder,lifan gy-5 |
I got a set from Lee's Cycle $11 shippied to my house. I have not installed them yet. so when I do I will post photo.
http://motors.shop.ebay.com/merchant/leescycle
-2005 Sierra SR200- |
#7 | |
I am not really sure how well they will work but I presume they will be okay and won't flash too fast or anything like that. They are just a plain old 12V LED. I know the stock bulbs are 10W each, not sure what the LEDs are for wattage. They only have one wire coming off of them. I think that is the wire that would connect to the "red" wire from the existing and the "black" wire from the existing will just be bolted to the fixture itself to form a ground. |
#8 | ||
#9 | |
http://www.bikerhiway.com/universal-...zer-p-235.html There are others here, as well as being cheaper the page has more useful info on converting: http://www.customled.com/PRODUCTS/TH..._equalizer.htm This is a thread on another forum with lots of explanations and tips. It seems that the fancy named "load equalizer" is nothing more than some power resistors on a heatsink, rated so the old flasher unit keeps on thinking it's a normal bulb. http://www.kawasakimotorcycle.org/fo...equalizer.html Something like this: This site has both the flush mounted lights and the equalizers: http://www.ezeran.com/main.sc
Jincheng Monkey JC50Q-7 (two of them) Skyteam Dax replica ST110-6 (two of them) Zongshen ZS125-43 Qingqi QM200GY-BA Super Motard Yamaha Virago XV1100 Triumph Bonneville SE Qingqi QM110GY PGO Bug rider 250 Buggy |
#10 |
Here is my setup: the front "winkers" (gotta love Chinese terminology) are flush on the barkbusters. The rear were originally mounted directly to the tail light assembly, I moved them later to this new position so they will be easier to see from behind. The tail light also has a moto clearance license plate bracket .
Mine do not blink too fast. In fact they blink quite slowly...on for about 2 seconds then off for about 1/2. ![]() ![]() ![]()
07 H-D XL883C 06 LF 200GY-5 Yin and Yang CAUTION Obey The Traffic Regulation. Always Wear a Helmet. Don't Ride After Drinking Wine. Before Operation, Read The Owners Manual Carefully. |
#11 | |
WHAT do you carry in that box? ![]()
#12 |
The flasher (capacitor) requires a certain rate of drain to work correctly. If the new LEDs have a similar wattage as the stock bulbs they should blink at about the same rate. Typically an LED pulls less watts so you end up with slower blinking rates.
Solution is to change the flasher with one rating for less watts. (Like Forchetto mentioned) Allen
