New Rear Sprocket
I need to adjust the rear sprocket on my '08 HSUN GY 200 to allow a bit higher top speed. It is geared very low - almost too low for street use.
Does anyone know what the stock sprocket size is? 46 tooth, 56 tooth? I want to keep the stock chain for now, I believe it is a 428. What size rear sprocket would allow a top speed of 65 mph or so? Any ideas on where to get a smaller rear sprocket that will fit? |
If you look at the sprocket it may have the tooth count stamped into it, mine does anyways...
I got my 46t rear sproket from Bruce at EJ Cycles.
I can run 65-70 no problem... This was the single BIGGEST positive thing I did to the bike. I should have done it right after I got the bike. I can run 60-65MPH at 25-30% throttle now.. instead of WOT. I actually would like to go a little smaller on the rear... a 42 is popular, but Bruce said he was out when I called... A 40t would also work.. you WILL need to cut your chain down. Be care full I cut too many links out and had to use a second master link to fix it temporarily. Bruce's number is 330-274-0098 http://www.endlessjourneycycles.net/ |
You probably have a 56T rear. Go to a 46-40T rear to get that speed. You will need to remove about 4 links from the chain.
Allen
#5 | |
Looks like I need to go to about a 46 or so. Thanks for all the help! |
#7 | |
Re: Check your front sprocket
Any link to the e- bay site? |
I have the same bike. My front sproket is a 17.
I put a 42 on the back (original was the 56) and I can hit 73-75mph without the air filter and jet mods.
Riding a blue plated HSUN 200GY (Otherwise know as a ULIKE 200GY, SUNL 200GY or a VIVA SX200S), a 2010 Gio Mini Hummer 110cc ATV, 2010 Gio T3 Rebel ATV, and a 2002 Kawasaki KLR650, 70cc Katera dirtbike, and a 49cc GIO dirtbike...so far! |
#10 |
With a 17/42 how is torque up a hill? Do you need to down shift at 60mph on moderate hills? I put a 49 on my Shineray and can get 65 on level and a tailwind and I weigh 250lbs. I get 55 at 90% throttle but still don't have the torque I'd like to see. I have a pod filter and main jet to put on as time permits.
Tim
Your mileage may vary... Shineray Allroad DB-200C |
#11 | |
#12 |
I was at the dealer today and I ordered a new 48 tooth sprocket for the rear, along with a new carb jet. I'm just trying to keep up with rest of you guys! :mrgreen:
Squishy: I'm really diggin' that windscreen! |
#13 |
Fun, Eh!
#14 |
What kind of sprocket did you put on and where did you get it Squish?
Thanks! |
#15 |
I got it from the Barrie, ON Honda Powerhouse www.barriehonda.com 1-800-267-4449 powerparts@barriehonda.com. But I think any dealer can get one in your local area.
JTSprocket 324-8702 (42Tooth Rear Sprocket) They also tell me the JTSprocket 324-8720 is a 45Tooth Rear Sprocket that fits the same bike. These where cross referenced against the Honda XL 100S (years 1977-78) If I may make a suggestion, I would have gotten the 4 little studs at the same time and put them on the sprocket before I started. Moving them from the original 56T to the new 42T was a bit of a pain. I had to remove 4 links from the chain (caveman style) and I have a 17T front sprocket.
