06-24-2008, 05:14 PM | #1 |
LF200GY-5 Transmission doesn't shift
2007 LF200GY-5 / 1064 km
Transmission won't shift, shifter moves but doesn't feel right, clutch works. Bike will move under it's own power, just can't shift gears... Removed kickstarter, rear brake pedal, disconnected clutch cable, thirteen (13) 8mm bolts securing clutch cover/case. Tapped on cover/case with wooden block until it broke loose from gasket... gasket was undamaged and reused. Found the bolt that secures stopper-plate to shift-drum loose and partially backed out. Stopper-plate no longer engaged pin mounted on shift-drum, or spring loaded stopper-arm (with roller) that holds transmission in gear. Used circlip pliers to remove circlip holding gearshift plate. (circlip, spring, then plate) Removed gearshift plate, bolt that secures stopper-plate, and stopper-plate. Held stopper-arm out of the way so stopper-plate could be positioned to engage alignment pin on shift-drum. Used thread locker on bolt and secured stopper-plate to shift-drum. Make certain the roller on stopper-arm rolls against stopper-plate. Replace gearshift plate, spring, and circlip... I used anti-seize compound on bolts during installation of clutch cover/case. Grease shaft on brake-pedal when you install, and use new cotter pins. Start to finish was four hours, including lunch break, pictures, clean-up, and test ride. Bike is now back in everyday service, shifts better than new.
Phil '18 FXBB Softail Street Bob '17 Tacoma TRD Last edited by Phil_R; 12-29-2017 at 02:43 PM. Reason: pictures |
06-24-2008, 06:01 PM | #2 |
Guest
Posts: n/a
Great Pictures, Thanks....
06-24-2008, 06:45 PM | #3 |
nice work. your pics/info I will be saving for my "rainy transmission day"
ALONZO 2007 Lifan a.k.a lucy lu. 2,000 miles of good riding. |
06-24-2008, 06:48 PM | #4 |
Very nice work!
2009 XR650L Big Red Pig Tusk bar risers 2007 X-Moto(Jetmoto) GY250 --mods--- 15/40 sprockets UNI Pod Filter 2007 Shineray TMS 200XYi--Betsy Betsy Mods:______________________ Acerbis DHH headlight FMF Powercore pipe Uni Pod Filter |
06-24-2008, 06:56 PM | #5 |
Nice post
06-25-2008, 12:43 AM | #6 |
Phil, Thanks for taking the time to put this all up in post. Isn't that the new counter balance shaft engine?
06-25-2008, 01:46 PM | #7 | |
Phil '18 FXBB Softail Street Bob '17 Tacoma TRD |
06-25-2008, 02:00 PM | #8 |
NICE
06-25-2008, 02:48 PM | #9 |
Great Post!
Very clear and concise. Fantastic pics. I think this could be kept in the tech info section permenantly. :wink:
IronFist ___________________________________ The "chain" of command is used for beating spammers. ___________________________________ |
06-25-2008, 04:49 PM | #10 |
Very cool post. Learn something everyday.
06-25-2008, 06:57 PM | #11 |
Good deal, and the best part is you fixed it yourself. Nice work and thanks for sharing.
06-25-2008, 07:54 PM | #12 |
Great detailed post. Thanks.
Kman 2007 HI-BIRD 250 2007 Vbike V4S 250 |
06-25-2008, 09:31 PM | #13 |
Nice job, thanks for the detailed post...
2001 HD Roadking 2008 Hi-Bird/Ricardo http://www.chinariders.net/gallery2/...g2_itemId=8088 |
06-26-2008, 08:43 AM | #14 |
Thanks Phil,
It is posts like this one that make "China Riders" so important for all of us. |
06-26-2008, 11:14 AM | #15 |
I created a sticky for great post like this. This one has been added.
Thanks Phil Allen
