Old 06-22-2008, 09:59 PM   #1
sarw15   sarw15 is offline
bike back fires when letting off
Ok i spent the weekend doing lots of mods
replace carb jets to 105s
cleand carb smooth for intake and air flow
Cleand ex pipe and took the stuff out from center of pipe looked like bees nest.
changed air cleaner to K&N
check timing
now bike has great power put when I let off it back fires
any one give me a clue??
Larry 2008 Roketa RKM-200E5, 200cc
Old 06-22-2008, 10:22 PM   #2
yurkia   yurkia is offline
check for air leaks around your exhaust head.
'09 Kawasaki KLR 650
'07 Zongshen 200cc Dirt Bike
K&N cone filter, FMF Powercore Exhaust, Moose Barkbusters & lotta threadlock.
Old 06-22-2008, 10:55 PM   #3
clean no leak checked that 1st thing but good thinking
Old 06-22-2008, 11:24 PM   #4
winnipegmike   winnipegmike is offline
I think its running too lean.
Old 06-23-2008, 05:47 AM   #5
It may be lean.
Check the spark plug it should tell you how its running.
If you changed the air filter and somewhat gutted the exhuast then you may have to go a bit larger on the main jet still.
When I did my K&N filter and changed the exhaust pipe to a free flowing one I went from a 98 main to a 115 just to get it to run good again.
But you really have to tune it to what YOURS needs to get it right.
Old 06-23-2008, 07:59 AM   #6
Ok thanks I will check it to night to see how lean it may be.
On the ride to work today ran great hit 90 KMH with easy
one thing I was trying to do was get some of the heat off the pipe and I think it helped.
tonight I will pull the pull hope its no I dont have any more jets I would have to order one :roll:
Old 06-23-2008, 08:22 AM   #7
elroyjetsn   elroyjetsn is offline
Maybe check idle mixture and adjust some for the new jet.
Wayne
Wildfire WF300-SP
Old 06-23-2008, 08:32 AM   #8
katoranger's Avatar
I think you will want a larger jet like. The 108 seems to be working good in mine, but I think I could go one step larger.
What elevation are you at. This will make a difference also.
Allen
Old 06-23-2008, 08:54 AM   #9
not sure of the elevation I'm in San Antonio, Texas about 120 miles from the coast
Old 06-23-2008, 09:11 AM   #10
DesertDog   DesertDog is offline
yes check the elevation, go to yur local bike dealer, (honda,suzuki,etc....)
ask them what jet size they're runnin in there bikes, mikuni jets are an almost perfect fit to these carbs,
the local dealers carry'em and i use'em, take yur's in to matchup the head and length, the pitch will be off about 1 turn from being tight, you wont strip it out.
i thought at lower elevations you run a much bigger jet and higher elevations a smaller jet,
my sons 250ccPR mx runs a 105 main with a 30mm carb at 5600ft thats what the honda dealer said he runs in his bikes up here .
i run a 122 main in my 300ccPR quad and the plug is medium brown but i also have a 42mm carb needed for for the 300cc.
so it all depends on elevation and what size a carb you run with the main jet
if in texas ?? my guess, buy afew jets from the dealer and test'em out as you step up in sizes, a 115 main sounds about right
i also run a dial-a-jet on my quad so i dont have to mess with jets ever again .
DD
DesertDog
