Old 06-21-2008, 09:57 PM   #1
Trebek   Trebek is offline
Back brake smoked...
Today I went for a long ride up a different canyon. After about 9 miles I noticed that the bike wasn't climbing hills worth a darn. I parked it and noticed that the back brake was smoking. Knowing what burning brake fluid is capable of I tried in vain to find some water to cool it down. The brake was friggin' hot!!! I didn't notice it was dragging because of the roughness of the terrain. The canyon stream was dry so I used some yellow colored human water to cool it down (it just vaporized). I waited for about 20 minutes and removed the brake caliper and tied it to my right passenger foot peg with my bungee cord.
Then limped on home using my front brake...
and avoided shaking hands with anybody...
Old 06-21-2008, 10:13 PM   #2
katoranger's Avatar
Congratulations. You have the rear brake problem. Pack your 8mm wrench so that you can relieve the pressure with the bleeder. The problem is the adjust on the master cylinder. You need to adjust the plunger bolt all the way out. My master failed completely finally and I put a honda cbr1000 master on it.
Been working fine since then. Took a little grinding to make it fit.
Allen
Old 06-21-2008, 10:15 PM   #3
1wickedmedic   1wickedmedic is offline
Do a search on this. There has been a lot of discussion about it. My buddies Komoto did the same thing. You would ride for about 20 minutes and then the back break would begin to lock up. His was a simple fix, just need the foot pedal adjusted by the adjustment screw. Some have found that the break fluid that the bike came with is inferior and have changed it to a better grade and this fixed it. When it first happen we called the company and they told us that the master cylinders where hanging up. Luckly this wasn't the case for him. There is also an adjustment at the master cylinder that could need adjusted. I would try adjusting the pedal first.
Old 06-21-2008, 10:18 PM   #4
katoranger's Avatar
Try the adjustment first. You can turn the plunger bolt with a pair of pliers. Turn it all the way out. Then turn the pedal adjuster all the way back too.
Allen
Old 06-22-2008, 12:58 AM   #5
dieselhead   dieselhead is offline
Be sure your resivior is not overfull (as mine was right to the cap)and get used to having about 2 an a half to 3 " of free petal. Smoked my disk 3 times before I put enough petal in it!
Old 06-22-2008, 01:43 AM   #6
Cool, sounds like an easy fix!
It didn't do this until It got dropped on the bike hauler the other day.
Old 06-22-2008, 10:46 AM   #7
alonzo   alonzo is offline
in the future try to avoid cooling the brake down with any water type substance. if the rotor is hot enugh you will squelch the steel and make it really brittle and suseptable to cracking and or shattering. :!:
