Thread Tools Display Modes
Old 08-15-2024, 08:33 PM   #1
oneb1jap   oneb1jap is offline
curious wiring y'all can just shake you head
have a chinese quad sitting for years so again decide to work on it
having already spent over the years 1 starter, couple/three batteries, wiring & switches.
so today finally have hopefully a correct magneto coi;
, etc.
NOW FIND 2 SETS OF WIRES COMING OUT OF MAGNETO COVER
i've never had it off due to no wheel puller - that I now have bought a set.
wish me luck
anyone have comments or advice?? CG250 water cooled
flywheel timing says CG125
thanks
Old 08-15-2024, 08:43 PM   #2
Crossbar   Crossbar is online now
May the luck be with you.
Old 08-18-2024, 12:23 AM   #3
Answer to first posting
turns out the other wire set runs into the engine case so must be for transmission neutral light.
end of thread?
Old 08-18-2024, 03:13 AM   #4
Thumper   Thumper is online now
It's a bundle of six wires? If so, probably the gear position indicator sender wires. The sender grounds one of the wires for each gear position, and one for neutral, probably.
No matter where you go, there you are
