Old 06-24-2024, 09:41 AM   #1
Hangkai 18HP 2 Stroke Outboard
Well I decided to get back into fishing again so i bought a nice used 15' aluminum boat and in the true Chinariders spirit, I ordered a Hangkai 18HP 2 stroke outboard off of Amazon that was fairly cheap compared to the name brand stuff. https://amzn.to/3xxVFOq I also installed an Tach/Hour meter. https://amzn.to/3REYNii
My first impression when I opened the box was it looked like a nice, well built motor. It included everything needed like the tank, gas hose, extra spark plugs, Impeller and gaskets. I took it out of the box and set it on my motor stand that i built. As per instructions, i added gear oil to the foot. I did a 25:1 mixture for the break-in as per instructions. Need to run this mixer for the first 10 hours then switch to a 50:1 mixture after. I hooked up the water to the foot, then pumped the bulb up on the gas line till hard. Pulled the choke and gave it a pull on the rope. I was shocked that it started on the first pull. Can't wait to get my trailer in so I can go take it for a ride.
2004 Honda ST 1300
Old 07-11-2024, 02:33 PM   #2
A buddy of mine gave me a boat trailer this week. He actually gave me a boat motor and trailer. Engine is shot and hull needs lots of TLC so I'll be parting them out. The trailer i ordered never did get here so I cancelled that order. I'll install the motor on Saturday and take her out for a test ride.
ID:	31697   Click image for larger version
2004 Honda ST 1300
Old 07-11-2024, 02:36 PM   #3
This is the boat and motor i was given. Looks god from afar but far from good looking. lol It has cracked ribs and broken welds all over. I'm not wasting any time messing with it. If i don't sell it within a week, it's being scrapped at the recycle yard.
2004 Honda ST 1300
Old 07-11-2024, 02:56 PM   #4
Those engines are relatively easy to rebuild. The pistons/rings might need replacement and new cylinder honing. Plastic/rubber parts might also need replacement, but everything else should be clean up only. The drive might need some work, but you can usually tell by manual turning. Even if the lower bearings are corroded out, those are cheap!
You have a nice Winter project there, and upgrade motor to put on another boat (or pull a skier with your flatboat !!!!).
No matter where you go, there you are
Old 07-11-2024, 03:07 PM   #5
Oh, i know. I've rebuilt plenty of outboards in my life time. I have a new motor and don't need another project. lol I actually have someone come pick everything up today.
2004 Honda ST 1300
Old 07-12-2024, 08:14 AM   #6
bigdano711   bigdano711 is offline
bigdano711's Avatar
I was looking at this very motor before buying my Hawk last year! I want to build the PM 38, a boat that Popular Mechanics put out the design for free in the magazine sometime in the early 60's, I believe. The plan is to power it with this motor.
The PM 38 was named because the cost of material was $38, could be built in 38 hours and would do 38 mph.
https://www.diy-wood-boat.com/PM-38-...e_Publications
Very interested to see how this little motor performs.
2023 Hawk 250 from XPRO off of Amazon
MOUNTAIN MAN RC + MOTO on YouTube
"If there were more bloody noses, there would be less wars." - Hagbard Celine
John 2:15 So He made a whip out of cords and drove all from the temple area, both sheep and cattle; He scattered the coins of the money changers and overturned their tables.
Old 07-12-2024, 08:53 AM   #7
That would be a nice project. I built quite a few boats in my day. My Grand father and one of my uncles were boat builders. The actually built LCVP Higgins boats in New Orleans for the military.
This little engine would be perfect. It is an exact copy of the Yamaha 15HP 2 Stroke. I'll take it on it's maiden voyage over the weekend. Guys on the FB group have hand no issues with the engine. Some have been running them for over 3 years. I've been running it o the water hose to start the break in. I'm still impressed with how it starts on the first crank even after sitting for a week.
2004 Honda ST 1300
Old 07-13-2024, 12:58 AM   #8
bigdano711's Avatar
The PM 38 is a basic runabout, 2 seater, 13 foot boat. Looks pretty simple to build. I'm thinking of using the glue and stitch method. Definitely glass the bottom and sides. Try to make it look really neat and maybe start selling them! That's my "old man" plan.
Old 07-13-2024, 06:10 PM   #9
Took her out on its maiden voyage. Motor ran so smooth. I definitely need more pitch on the prop. It came with an 8 pitch prop. I ordered a22 pitch. Top speed with the 8 pitch was 24mph @6200 rpms. I need to get it down to about 5500 rpms.
2004 Honda ST 1300
Old 07-14-2024, 05:37 PM   #10
Painted the boat today. It was frickin hot. Heat index was 107°. No problem with the paint drying. Lol
2004 Honda ST 1300
Old 07-14-2024, 07:07 PM   #11
jeffrey   jeffrey is offline
I have that very magazine dated August 1962 for 35 cents. Build a 38-m.p.h Fun- Boat-for $38. Sorry for interupting your thread Jerry.
Old 07-14-2024, 07:15 PM   #12
Dan there is another little boat called the Glenn L Squirt that looks good too.
Old 07-14-2024, 07:19 PM   #13
Originally Posted by jeffrey View Post
I have that very magazine dated August 1962 for 35 cents. Build a 38-m.p.h Fun- Boat-for $38. Sorry for interrupting your thread Jerry.
You're not interrupting my thread. It's a boat and motor thread. Post away.
2004 Honda ST 1300
Old 07-14-2024, 07:59 PM   #14
bigdano711's Avatar
Heard of it...pretty sure I even looked at it. I keep coming back to the PM 38. I should probably look for a proper stitch and glue simple boat to build first before attempting the PM 38. I want to basically take the same shape as the PM 38 but modify certain areas for stitch and glue. I'm sure you guys know more about it than me. I'm subscribed to Salt Boatworks channel on YouTube. That's about the extent of my knowledge. lol
Old 07-14-2024, 08:06 PM   #15
bigdano711's Avatar
That thing purrs just like my Hawk. Very nice. Can't wait for some WOT footage.
