Old 05-26-2024, 02:49 PM   #1
ProDigit   ProDigit is online now
XPro- Vader / Condor 150 build complete, parts list.
This is a new thread summarizing the main mods I've done so far with parts, that makes my Vader 150 (same for Condor 150) complete.
My intent was to keep the bike as stock looking as possible, and making it better for a commuter bike.
If I were to mod a similar bike like this again, I would purchase and install the items listed from the get-go.
The bike currently has about 800 miles on it, so certain mods may not work well on a brand new bike that still has to go through the break-in.
0- Generic Parts you'll need:
I use a bolt and nut variety assortment for most of my builds, rather than go to the store and get a bolt or nut of specific sizes, which can end up costing more than a variety pack.
https://www.aliexpress.us/w/wholesal...37323e26cBjwcD
And blue Loctite:
https://www.amazon.com/dp/B0C8Z81WQL
I personally use Lithium grease for my chain. It's less sticky than the other stuff out there, attracts less debris and sand:
https://www.amazon.com/dp/B004X70LZA
Most of my chains have lasted 4k miles at least, this is without stunting, but a lot of highway.
I also use a coat of black Rust-Oleum paint on all bolts, nuts and black pieces of frame or other, where bare metal can be seen, or rust can form. This includes pins, cotter pins, washers, nuts, bolts... Half a can is more than enough:
https://www.amazon.com/dp/B003CT4AKC
Additional coating for areas on the bottom of the frame, subject to mechanical impact from pebbles, road debris, sand, etc...; using black Plastidip (overcoating the Rust-Oleum paint). Need less than 1/2 can per bike. Additionally you can paint your rims with this stuff, in any color they offer.
https://www.amazon.com/dp/B0093B541M
After coating my chain with lithium grease, I paint it with plastidip, decreasing the surface area that can rust on the chain, lengthening it's life.
Main mods
1- swapping sprockets
From the stock 15/34T to a 17/29T (easy),
or if you don't mind grinding down 1/4 inĀ² off the sprocket cover (where the starter/stator meets), a 18/30T would fit best.
Sprocket 10-19T (18T): https://www.amazon.com/dp/B07L9XDZ1Y
Rear sprocket, 29-45T (31T) fitting Honda Grom. Ordered from Rebel Gears: http://www.rebelgears.com/customsprockets.html
You got to call them. Apparently they don't look at their online orders.
If anyone finds custom sprockets (non-34T) cheaper than this, please comment!
2- change the exhaust.
https://www.aliexpress.us/item/3256801430668038.html
Saves lots of money.
Get silencer tip if not included: https://www.aliexpress.us/item/3256805991031626.html
Silencer tip needs an additional 8mm nut installed on the bolt that holds it to the muffler.
Also Loctite it!
The silencer tip only handles about 125cc. This bike is a 138cc, and the exhaust tip (silencer) is only spot welded at 3 spots. Many people have complained that it's not strong enough.
I'm still looking into welding or soldering it tight.
You'll need to use an angle grinder, to grind off about 2mm on the front motor mount, for the exhaust to fit.
3- Exhaust also needs an additional baffle installed, aside from the silencer tip.
Remove the silencer tip, remove the bottom screw holding the end cap, just mount the silencer baffle below in series with the silencer tip, using a longer bolt like a 50mm M12, and use the end cap on the baffle.
Color B2 (black, 140x35mm) https://www.aliexpress.us/item/3256805619827020.html
This will cause the bike to be quieter at higher speeds.
4- Carburetor swap
I used a replacement PZ27, since my OEM carburetor was too rich at idle, and I couldn't find replacement jets.
You'll need the one with the cable choke: https://www.aliexpress.us/item/3256806111422392.html
5- Jetting
You'll need a 112 main jet at sea level, 110 main jet in hot dry air, or the 108 pack if you live at an altitude exceeding 100ft above sea level.
https://www.aliexpress.us/item/2255800184285871.html
The PZ I bought comes with a 35 pilot jet, which is somewhat lean in my area, but 2 full turns out on the A/F screw really fixes most issues, except for minor exhaust rumbling when decelerating.
I would recommend a 38 pilot.
Idle jet suggestion (not tried): https://www.aliexpress.us/item/3256803993422214.html
6- Intake
Florida air is clean, so I used the stock air filter included with the PZ27.
I'd recommend the ones with a short of a nozzle as possible.
The curved ones aren't necessary, and only reduce performance.
Aluminum tubes also aren't necessary. They help with low RPM stability, but take off some top end power.
https://www.aliexpress.us/item/3256806331905330.html
7- Seat
- Generic foam (cut to size), recommended 10x35x50: https://www.aliexpress.us/item/3256805381382734.html
- All weather seat cover (medium AND large): https://www.aliexpress.us/item/3256806119261481.html
Put foam on seat, cover with medium cover, then cover with Large cover.
- Top it off with 3D mesh fabric seat cover (good for hot weather): https://www.aliexpress.us/item/3256805773671331.html
Will improve seat comfort for longer journeys drastically.
The foam I used was slightly more firm, but lots more expensive.
It has enough foam for several seats: https://www.amazon.com/dp/B07S6ZY5J9
8- Handlebar Risers
The Vader 150 comes with 1" handlebar risers.
You can remove them, and instead install 1.25" risers, and install the stock handlebar risers on top, for a total rise of ~2" (5cm).
https://www.aliexpress.us/item/3256805674641534.html?
You just need 60-65mm bolts to mount both of the risers on the bike.
https://www.aliexpress.us/item/3256803277662297.html
