03-13-2024, 09:01 PM | #1 |
Solved!! PR250 6 speed engine DC CDI 2024 Templar
Okay so I finally figured out this DC CDI wiring.
The 2022? Templar 5 speeds are AC CDI For many dc cdi engines pin sequence is typically igniter, coil Ground, ground Then 12 v positive on the two pins. The pin sequence for the 6 speed is Igniter, coil Ground, 12v Then the two pin connector is completely disconnected. When you ohm out the typical dc cdi on the two grounds they are connected internally. When you ohm out the 6 speed cdi it’s NOT connected internally. Anyways I figure this is kind of a public announcement stating dc cdi s are NOT created equal. Spread the word! It was a huge pain for my microcar project trying to get her to fire! |
