Carbed hawk front tire clearance?
I took all the plastics off my bike and painted it the other day and noticed that my front wheel is considerably closer to the side that brake is in on. Is this normal? Just from looking the fork doesn't look bent or anything...Can't seem to find a photo of the carbed hawk at a good angle to check this. However sometimes the brake seems to drag a bit and sometimes it doesn't? If it's off the ground and I spin the wheel I can hear a slight drag at a certain spot, however if it's on the ground and rolling it's a 50/50 if I can hear it dragging or not.
Can anyone confirm or deny? |
Assuming that the front fork doesn’t have a twist in it, and all nuts and bolts are tight, then a bearing seems to be falling. Thinking out loud here. Just my thought…
#3 | |
I do already have replacement bearings and seals here, suppose I could take a look but the front rim is new-er. Has maybe 500-700 miles on it. |
Double check the distance from the bottom of the lower triple tree to the axle center on both sides and see if they are uneven. My Hawk was the same way out of the box, and I discovered that they every so slightly misaligned the holes for the axles on the fork lowers. I have to install my left fork just a tad higher than the right side. That may be your issue too.
#6 | |
Thinking my wheel is out of true. I bent mine last year and got a new one and I'm guessing it came un-true. I assumed since it was new it would be true. Made an ass outta myself.
I went ahead and ordered tire irons, lube and a truing wheel/stand. Figure I'll need this stuff eventually as I plan on getting another bike in the next few months. Wish me luck ya'll, I'm a newb at all this. |
#8 | |
#9 | |
I suppose if trueing the wheel does not work I will order new forks and hope it does? I've heard the TBR7 forks fit and a pair is only about 80 bucks. |
