01-20-2024, 01:39 PM | #1 |
CG250 with reverse
I'm interested in using a CG250 engine with reverse on an ATV project. I noticed that reverse is typically where 1st gear would be (R-N-1-2-3-4). Would it be possible to accidently go into reverse while moving forward? Are there any disadvantages to using this engine over the 5 spd dirt bike engine?
AJPMike |
01-20-2024, 01:58 PM | #2 |
Yes you can hit reverse while moving foreward ,scary on a dirt bike ,that’s all the disadvantage you need to know if you are putting it in a dirt bike .They are usually electric start only.I put one in an xr200 frame,no good so swapped it out for a bike engine
01-21-2024, 05:18 AM | #3 |
Unlike a normal motorcycle engine where you can shift past neutral, in an ATV engine it takes 2 clicks of the gear lever to get from 1st to reverse or reverse to first.
01-21-2024, 08:35 AM | #4 |
One click after 4th with the common circular shift pattern and you are in reverse hell .
01-21-2024, 04:34 PM | #5 |
Are you saying you can shift past 4th gear and end up in reverse?
01-21-2024, 06:14 PM | #6 |
Yes if you have the circular shift pattern .
01-22-2024, 06:45 AM | #7 |
I've never heard of a CG engine with reverse that also has a circular shift pattern. It wouldn't make sense.
01-22-2024, 07:46 AM | #8 |
I have had 4-5 come through my shop ,all the same make and model ,I don’t do much Chinese atv work and I no longer work on those particular machines as they are garbage by the time I see them .I agree ,they do not make sense ,actually any circular shift pattern bike are a dumb idea as well ,but they are out there unfortunately .
01-22-2024, 08:44 AM | #9 |
I own a 2018 Taotao Rhino with a CG engine that is approaching 3000 hours with zero engine issues. It has only had oil changes and valve adjustments and a new spark plug. I used to have a Taotao ATA250d that I bought used that also had zero engine issues. Very reliable engines. Both have reverse gear.
01-22-2024, 09:27 AM | #10 |
I think I will get one for my project. I can live with the shift pattern. I was just concerned that you could hit reverse accidently but I don’t think it will be a problem. Thanks for the help.
Mike |
01-22-2024, 09:36 AM | #11 |
Many years ago, my wife had a Bridgestone 175 Hurricane Scrambler, that had a dual shift pattern, it was either conventional, or rotary, depending upon which you selected.
The pics are not of her bike, it was a bike that was sold at auction last November. |
