Pentora 250 Carb issues
Hi,
I just purchased a pentora 250 and the carb bogs like crazy, when its warmed up it still hesitates but not as bad and has no top end , If i apply the choke while riding partially it has a surge of power and top end and runs normally. This points to the bike running lean . I Reached out to support and they send a new carb, this one now runs good but still lacks the top end. I tried adjusting the needle under the carb but this seems like its a low speed needle as it only affected the take off performance I have an o2 sensor on the bike to monitor the afr. The top end runs very very lean and I am hesitant to ride it like this. Is there a recommended aftermarket carb that anyone recommends? |
Anyone ?
Replace the main jet with a larger jet to richen it up on the top end.
Thanks for the reply , Is this normal? to have to re-jet a new ATV? Is this common with this 250?
Yes, it is common. Just about all the bikes and ATVs come tune lean in order to pass EPA approval.
I have a different bike but had a jet tuning kit bought and shipped to me before I even received the bike. Thanks to the heads up from multiple members of this forum. And yes, I needed to richen it up.
