12-30-2023, 09:17 PM | #1 |
Hello
My family, friends and I mess around with gokarts. Nothing competitive, just having fun. I picked up an used frame a few weeks ago. Instead of building up a Honda gx200/clone/predator, like i have in the past, I've been kicking around the idea of a gy6 or Zongshen 250. They are about the same money as buying a predator and building it up to 15+ hp, and you get a transmission.
I landed here a few times while I was poking around, might as well register. |
12-30-2023, 10:18 PM | #2 |
Hiya.
12-30-2023, 10:38 PM | #3 |
Welcome.... lots of good info here.
12-30-2023, 11:02 PM | #4 |
Welcome..sounds like you've dabbled a bit.
2022 Hawk DLX EFI * 17T Front / 47T Rear / upgraded chain * Kenda K-760 front + rear * Banjo brake light switch * LED headlight + front turn signals * Debadged (I don't like to brag about the superior strength!) * Top speed, GPS verified, as equipped: 68 mph (so far) |
12-31-2023, 05:04 AM | #5 |
Welcome aboard! Those gy6 engine are tuff. I have one on an ATV that's 10 years old and still runs perfect. My daughters UTV also has the 169cc gy6. Both will do well over 20 mph.
12-31-2023, 10:16 AM | #6 | |
Are you engineering a foot operated clutch? Gokarts are typically two pedal (go/stop). You can place a third pedal there!
12-31-2023, 11:22 AM | #7 |
Probably hand operated, although foot would be what I'm used to. It has pedals already, as well as front and rear hydraulic disc brakes. It looks to be a kart of European origin, likely intended to be operated with a water cooled 2 stroke and a transmission.
12-31-2023, 06:27 PM | #8 |
Hi just thinking of building one my self. Will be 250cc for sure.
