12-17-2023, 10:13 PM | #1 |
Anyone using a wide 19" front tire?
I plan on mounting a nice wide front tire on the Brozz Recon 250. Riding mostly off-road but want DOT legal. Looks like a Kenda K760 trakmaster will help with floating over the soft ground. 120/90-19 is what I plan on using.
The design of the front rim is what I'm concerned about for the tire bead to set in properly. Anyone else ever tried this before?
2020 Bashan Brozz Recon 250 |
12-18-2023, 01:12 AM | #2 |
The Bashan Brozz are 19", right? Should be readily accessible online somewhere.
12-18-2023, 03:33 AM | #3 | |
What size is the OEM dual sport tire on there. I thought I got the same size.
12-18-2023, 08:24 AM | #4 |
Yes 19" front rim. Not a question of being readily accessible. Fitting a Much larger tire on a narrow rim is my question.
12-18-2023, 08:32 AM | #5 | |
01-01-2024, 01:27 AM | #7 |
Cool! Looks great. Is that a 19" wheel? Rear tire on the front!? Good idea!
01-01-2024, 08:31 AM | #8 |
Yes, the stock rims for the 2020 models are 17" rear and 19" front. That is a 19" rear tire on the front. Getting a larger rear tire, 130/90-17 and that should even out the look. Also have a 15/50 sprocket setup for better off-roading.
01-01-2024, 10:25 AM | #9 |
Nice set up! I like the Recon. I have a Bashan Storm which has the same inverted forks, same wheels, and lots of other identical parts. It is really a dependable bike.
