Front Sprocket Question
Looking to go from a 13 tooth to 17 tooth on a 520 chain.
Are there any reliable or preferred vendors to buy from? New to the forum and new owner so just trying to figure out best options. |
That's a pretty big jump. If you haven't already, check to see if there is room in the front sprocket area to fit a 17 tooth. Both at the front but also at the rear, near the swingarm.
More typically you can go up a tooth or two. You might have to do a combination of larger front and smaller rear to get the ratio you want.
More than likely a 14 tooth will be the largest that will fit.
Thanks for replying back, most appreciated. Do you have a suggested vendor or website that is reliable and go to for these types of parts?
#5 | |
I've started adding parts on my website to have all the information in one place. I still have a lot to add to it. https://jerryhawk250.com/index.php/kpx-parts/
