10-17-2023, 01:20 PM | #1 |
Check this on your Hawk DLX 250
Whilst doing some other mods, I had the seat off and noticed the ECU was only held on by one screw. The odd thing is, one side looks to have been drilled out for a bolt, while the opther was still being held on with a sheet metal screw. Drilled it out and used 2 bolts with loctite. Just a heads up.....
11-09-2023, 05:46 PM | #2 |
Mine has two bolts
Bought mine assembled and tested from TPS and picked it up there as I’m local. This is what came installed.
DFW HMCM(SW)[Ret] 2020 FLHTK 2023 EX400G Ninja 400 2023 Hawk DLX |
11-09-2023, 06:57 PM | #3 |
Bought mine used. Previous owner was on top of things and secured the ECU with 2 bolts.
2022 Hawk DLX EFI * 17T Front / 47T Rear / upgraded chain * Kenda K-760 front + rear * Banjo brake light switch * LED headlight + front turn signals * Debadged (I don't like to brag about the superior strength!) * Top speed, GPS verified, as equipped: 68 mph (so far) |
