Lifan KPX oiling issue.
http://
Well that sucks. In the mean time you can go to the local hardware store and pick up another o ring so you can continue riding. My cover was hard to pull of the first time. Second time was much easier once it had oil on the orings.
I am not really worried about buying an O Ring. It's the fact that I couldn't have had good enough oil pressure, or filtering when I ran it. It seemed to be running fine, before I drained it, but with these motors being a little noisy to start with, I don't know if it was making abnormal noise. I would hate to have un necessary internal wear. The two O-Rings are what holds the pressurized oil between the passage hole in the housing.
#4 | |
I just got done spend them pictures of the issue. I probably seem like a complainer to them, but I maintain my vehicles, and do my part to help them last, and would hate to not get long life front engine.
I actually got a run a round at Venom, and ,I feel that they were trying to blame me, as if I don't know how to change oil. The damage to the O Ring was obviously done during assembly, and couldn't have been done by me removing the filter. They are acting like they will send me one as a courtesy.http://
![]() I just realized it's your video that they linked Jerry. LOL |
Don’t worry it’s a standard corporate speak reply when I read it. I didn’t pick up any inferences that you didn’t know how to change oil. They are just covering all the bases in as neutral a reply as they can.
What I really want to know Bill is, when did you change your name to Debbie?
![]() Don't worry too much, You didn't loose oil pressure without the O-ring. I just didn't all pass through the oil filter. It looks like they will send you the O-ring and a filter.
#9 | |
Onhttp://
![]() ![]() ![]() Quote:
My bike was a day late getting here because they had the bill of laden mixed up the had the house number correct, but had the wrong street. When I called they had a Debbie as the person on Affirmed Drive. I actually had a hard time finding an O Ring.that diameter, but thin enough. I eventually had to buy a kit of O Rings at Advance Auto to get one. It was basically $6.00 after tax, but at least I could ride. While riding, I went to thinking that I could have took the o ring off the outer groove, and put it on the inner groove, and used a thin paper gasket on the outside. Oh well it's fixed, and I went on a pretty good ride.. The power is fantastic on the bike, but it has a dead hesitation right off idle, especially when cold. It acts like a carbed bike not really warned up, but idling alright, with the choke open,but might fie if you touch the throttle . Other than that I like it. Here are a few pics, but I'm not really going on any rough terrain on my new bike yet. They are the old bridges at Sarvis Fork, and Little Creek, and some from up on the hill between Tug Fork, and Buffalo Lick. I like the way the sun is above the bike in the one picture http:// ![]() Last edited by Bill Hilly; 10-13-2023 at 06:03 PM. Reason: Pictures |
