08-12-2023, 02:41 PM | #1 |
Hawk 250 assembly (spring)
Hi all,
Just got my first bike yesterday I've got it all assembled and ready to go except I cannot figure out for the life of me where the second spring goes that came in the package with the nuts and bolts. The smaller spring went to the brake pedal for the brake light and the larger spring I have no clue. Also anybody else have extra parts after assembly? |
08-12-2023, 02:44 PM | #2 |
I assume you ain't put the kickstand on yet. LOL. That's what it's for.
08-12-2023, 03:02 PM | #3 |
The stand came already assembled on the bike, and it stays up when you put it in the up position but I'll go out and take a look, thank you.
08-12-2023, 03:17 PM | #4 |
I can't really tell how big it actually is, but you said one was for the brake LIGHT, but it may be for the brake pedal itself. I will go out, and look at a bike.
08-12-2023, 03:30 PM | #5 |
http://If it's not for the kickstand, then it's for the brake pedal. I bought both my TBR7, and Hawk used, and only the TBR7 has it, but the Hawk was evidence supposed to have one as well, because it has a small prong sticking down on the underside of the piece that the foot peg hooks to, and that's were the spring is hooked to on the TBR7. I don't know if mine on the Hawks has just came off, or never was put on. I had never even noticed it..[/IMG]
08-12-2023, 03:31 PM | #6 |
The larger spring is also for the break pedal. Return spring. I'll get a quick pic and post it up.
2023 Hawk 250 from XPRO off of Amazon MOUNTAIN MAN RC + MOTO on YouTube "If there were more bloody noses, there would be less wars." - Hagbard Celine "Someday, after mastering the waves, the winds, the tides and gravity, we shall harness for God the energies of love and then, for the second time in the history of the world, man will have discovered fire." - Pierre Teilhard de Chardin |
08-12-2023, 03:38 PM | #7 |
08-12-2023, 03:41 PM | #8 |
X-Pro has a pretty good assembly video:
08-12-2023, 03:46 PM | #9 | |
08-13-2023, 11:18 AM | #10 |
Thanks for all the replies, much appreciated. It was the brake pedal return spring it didn't click at first because the brake pedal was returning on its own without it.
I've got another question maybe I need to start a new thread but now that I've got it all together and have got it running it does not want to stay idling I'm at 5,000 FT elevation thinking maybe I need to Jet it but also considering getting the 28 mm Nibbi carburetor and air filter package, any thoughts on the subject. I don't have experience jetting at this elevation, my carbureted sleds were jetted at the dealership and my new one is fuel injection. |
08-13-2023, 12:22 PM | #11 | |
08-14-2023, 02:25 AM | #12 |
Actually, you are correct, this is the part number that I ordered.
Thank you for your input, (and everybody else's too) much appreciated. I am a snowmobile and ATV vet, but a newbie when it comes to motorcycles, just starting the game. |
08-15-2023, 04:11 AM | #13 | |
08-15-2023, 02:06 PM | #15 |
Adjust the valves! Mine had the typical zero clearance. I have the Nibbi 28mm and like it. Also check the float height while you are rejetting. Bottom of the float should be 18mm from the lip of the carb when tab presses the pin, but does not compress the spring. If you have it set any less than 18mm, it fills the float bowl with too much fuel and the bike floods when you hit bumps. Ask me how i know.
